Re: Check out this video...tire separating from the wheel
[Re: EvilB1Dart]
#1272442
07/23/12 06:37 AM
07/23/12 06:37 AM
Posts: 6,150 Melbourne , Australia
LA360
That is kinda scary! I think that realistically, that car needs bead locks, I don't think I have ever seen a rear wheel with that many rim screws!
Alan Jones
[Re: EvilB1Dart]
#1272444
07/23/12 10:11 AM
07/23/12 10:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm wondering if its just a radial thing... but you could see that it pulled in to the screws(and he sure has enough of them... if I had to put that many in I would have gone to bead locks) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: LA360]
#1272446
07/23/12 10:37 AM
07/23/12 10:37 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
He is running a slick. It is not a drag radial.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1272449
07/23/12 01:37 PM
07/23/12 01:37 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Another DR guy that would have been DQ'd at our track before he staged....Can't go past the line doing a burnout with a door car.
So a outlaw 10.5 car can't go past the starting line on the burnout at your track? Wow I guess you don't run any of them there.
We get a couple of them now and again...Can't say I have seen a whole class of them run. Still not allowed to go past the beams...DQ'd! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Dragula]
#1272450
07/23/12 01:49 PM
07/23/12 01:49 PM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
For the record; Charlie doesnt run a radial tire, he runs a 28x10.5 stiff side wall slick. He's has many championships with NMCA and NMRA Hotstreet and Pro Stock under his belt with that stang! Charlie is a good guy! And by the way, that car now sports a Pro flight trans. ![](/ubbthreads/images/graemlins/thumbs.gif)
It's a bigblock with a torque flight!!!
[Re: mopar_to_ya]
#1272452
07/23/12 03:20 PM
07/23/12 03:20 PM
Dragula
Who's making those? And what is it exactly?
I see Transact has a set of straight cut gears comming out and a conversion to convert a 727 into a two speed trans with different 1st gear ratios available soon according to their website.
[Re: EvilB1Dart]
#1272455
07/23/12 08:51 PM
07/23/12 08:51 PM
Posts: 20,671 in a cattle trailer down by th...
Guitar Jones
Yeah, I think if I saw that on my car there would be beadlocks on it the next time out.
[Re: Crizila]
#1272457
07/23/12 09:50 PM
07/23/12 09:50 PM
Guitar Jones
How about just getting the right size wheels for the tires. There is an accident waiting to happen - not to mention not getting good use of the tire foot print.
A lot of racers, especially the small tire guys are using wider wheels by an inch or so of the tread width. I think the reasoning is that they can run more air pressure and keep a flatter footprint, at least that's what I heard. ![](/ubbthreads/images/graemlins/shruggy.gif)
