Speedo needle bouncing after gear change?!? #1271938
07/22/12 02:25 PM
07/22/12 02:25 PM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
I replaced the 33 tooth speedo gear with a 32 tooth gear in my 727 transmission. Now when I drive down the road, my needle bounces all over the place.
I was wondering what could be causing this? It didn't do it before I swapped the gears, and there didn't seem to be anything wrong with the new/used gear that I put in? No missing or damaged teeth.
It's already 95 degrees here, so I'm letting the exhaust cool down before I crawl back under there.
Any ideas?!? Thanks for any and all help!!
1970 Duster 340 clone
Re: Speedo needle bouncing after gear change?!? [Re: BrianT] #1271939
07/22/12 02:36 PM
07/22/12 02:36 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Did you make sure you got it indexed correctly????
Re: Speedo needle bouncing after gear change?!? [Re: MoparforLife] #1271940
07/22/12 02:40 PM
07/22/12 02:40 PM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
Sorry, forgot to mention that. It is correctly indexed. Thanks.
Re: Speedo needle bouncing after gear change?!? [Re: BrianT] #1271941
07/22/12 03:47 PM
07/22/12 03:47 PM
Check that the cable is correctly seated on both ends
Re: Speedo needle bouncing after gear change?!? [Re: RapidRobert] #1271942
07/22/12 06:24 PM
07/22/12 06:24 PM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
Also make sure there are no kinks or sharp bends in the cable. Sometimes you have to move the cable around so it stops.
Eric
Re: Speedo needle bouncing after gear change?!? [Re: Erics5th] #1271943
07/22/12 07:48 PM
07/22/12 07:48 PM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
Thanks guys. It got up to 101 today and after working on the car Friday night and Saturday afternoon, I decided to let it sit today.
I'll pull the cable back out later in the week and see if I can see any trouble?
