Tuning question #1271552
07/21/12 03:12 PM
07/21/12 03:12 PM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
I am working with a buddy on his heavily customized early eighties Jeep. Decent cam, Holley carb, MSD everything, headers, bIg stall convertor, big rear end, etc..
Anyway, idle performance was very poor, stalling all the time, very rough idle, even a high idle speed didn't help it. After playing with the carb (floats, mixture) I bumped the timing up a bit. Was 18 initial and now probably in the low twenties. Did it by feel and ear as well as with a Full Advance timing light. Really, really, improved the Jeep, but now at around fifty or so, at steady speed, it "bucks" a bit. Detonation? That was my thought and I can back off on timing, but I wanted to see what others thought.
It has vacuum advance hooked up. The Jeep bucked more with the advance disconnected than connected. Hence my confusion.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Tuning question [Re: Kowal] #1271553
07/21/12 07:21 PM
07/21/12 07:21 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
How much vacuum is it pulling at idle and cruise and is it steady or bouncing all over the place?
383, Hemi 4-Speed, AlterKtion, D60
Re: Tuning question [Re: Kowal] #1271554
07/21/12 08:21 PM
07/21/12 08:21 PM
Check rotor phasing. Drill a 1/2" hole in the top flat of the dist cap 2/3 of the way between the center terminal & the #1 terminal & shine your timing light straight down on the rotor at the offending RPM & see if the rotor blade is close to the #1 cap terminal then disconnect the vac adv & check again
