´68 - ´69 Dart front end on a ´75 Dart? Doable? #1271539
07/21/12 02:47 PM
07/21/12 02:47 PM
Iceland
BadMoonRacer Offline OP
Iceland
Hi there
What does one have to change (and will it fit?)besides bumper, grill and probably hood if one wants to put a ´68 or ´69 Dart front end on a ´75 Dart?
Thanks for replying.
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable? [Re: BadMoonRacer] #1271540
07/21/12 06:16 PM
07/21/12 06:16 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You would need to swap all the sheetmetal from the windshield forward. And you may have to be creative adapting some of the wiring for the front lights.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable? [Re: BadMoonRacer] #1271541
07/21/12 06:26 PM
07/21/12 06:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
70-72 is much easier. and it will look better. not sure the body lines on the 67-69 will match up.
Coming soon!!!!
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable? [Re: Mr.Yuck] #1271542
07/21/12 06:56 PM
07/21/12 06:56 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Everything lines up from 1967 to 1976. Wiring is different, but certainly can be modified. I had a '68 clip on a 73 Dart Sport for awhile. Side marker lights are different, but if you welded them over, nobody would know.
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable? [Re: Kern Dog] #1271543
07/21/12 10:06 PM
07/21/12 10:06 PM
Iceland
Iceland
Thanks guys for your informative responses. I am contemplating adding a ´75 Dart to my collection, but due to the fact that I like the ´68-´69 front ends; I wanted info about if this was possible. You have all been helpful.
Regards
Ragnar in Iceland
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable? [Re: BadMoonRacer] #1271544
07/22/12 01:10 AM
07/22/12 01:10 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Id be finding a 70/71 nose fir it. Much better looking than the 67/69 or the 73+ noses. The 72 would do in a pinch. I dont like the size of the 72 blinker lights..
I am truckless..
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable? [Re: 340SHORTY] #1271545
07/22/12 09:21 AM
07/22/12 09:21 AM
Berlin, N.J.
abodyjoe Online content
abodyjoe  Online Content
Berlin, N.J.
Yes you can do it pretty easily but you'll still have the ugly rear end. I think the car would look horrible all mismatched like that
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable? [Re: abodyjoe] #1271546
07/22/12 11:56 AM
07/22/12 11:56 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
In 1984 I saw a 67 Dart coming towards me and as I passed it was a 74 Dart Sport!
JB Rhinehart, Realist
A-Body's RULE!
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable? [Re: BadMoonRacer] #1271547
07/22/12 03:47 PM
07/22/12 03:47 PM
Canada
demon Offline
demon  Offline
Canada
Hi there
Ragnar in Iceland
the fenders bolt right on and will match up fine. The grille will as well but a couple holes might need to be drilled in the rad support. The hood will bolt on, but the 71 up A bodies have large slots in the hood hinges up just be aware of that. The front bumper will present a problem because the 1975 has the shock absorbers which use different holes in the frame rails. You would need to drill and tap new 1/2" holes to bolt the 68-69 brackets on.
I have to agree though about the mismatch looking odd. The 74-76 rear ends are not very cool looking. The rear could be modified to accept the 70-73 rear bumper and valance quite simply and with a 72 front clip one could make a 72 lookalike fairly easy
