´68 - ´69 Dart front end on a ´75 Dart? Doable?
#1271539
07/21/12 02:47 PM
07/21/12 02:47 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Hi there
What does one have to change (and will it fit?)besides bumper, grill and probably hood if one wants to put a ´68 or ´69 Dart front end on a ´75 Dart?
Thanks for replying.
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: ´68 - ´69 Dart front end on a ´75 Dart? Doable?
[Re: Kern Dog]
#1271543
07/21/12 10:06 PM
07/21/12 10:06 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Thanks guys for your informative responses. I am contemplating adding a ´75 Dart to my collection, but due to the fact that I like the ´68-´69 front ends; I wanted info about if this was possible. You have all been helpful.
Regards
Ragnar in Iceland
[Re: BadMoonRacer]
#1271547
07/22/12 03:47 PM
07/22/12 03:47 PM
Posts: 1,179 Canada
demon
Canada
Hi there
Ragnar in Iceland
the fenders bolt right on and will match up fine. The grille will as well but a couple holes might need to be drilled in the rad support. The hood will bolt on, but the 71 up A bodies have large slots in the hood hinges up just be aware of that. The front bumper will present a problem because the 1975 has the shock absorbers which use different holes in the frame rails. You would need to drill and tap new 1/2" holes to bolt the 68-69 brackets on. I have to agree though about the mismatch looking odd. The 74-76 rear ends are not very cool looking. The rear could be modified to accept the 70-73 rear bumper and valance quite simply and with a 72 front clip one could make a 72 lookalike fairly easy
