Edelbrock Dp4b intake-how rare are these and where can #1271466
07/21/12 10:41 AM
07/21/12 10:41 AM
Vancouver,Canada
70 Roadrunner* Offline OP
Vancouver,Canada
I'm looking for one of these to put onto my 383 N-96 hooded car...I'm just wondering how rare or how hard to find is this aluminum intake or where I might start looking.
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: 70 Roadrunner*] #1271467
07/21/12 10:43 AM
07/21/12 10:43 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
DP4B= dual plane 4 barrel,
easy to find, don't pay more than $75.
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: Dan Halen] #1271468
07/21/12 10:46 AM
07/21/12 10:46 AM
Vancouver,Canada
Vancouver,Canada
No more than 70$...thanks for the advice.I've been reading that they are still a good intake and with my air grabber hood I'm limited by height...this site has helped a new guy like myself big-time!
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: Dan Halen] #1271469
07/21/12 10:46 AM
07/21/12 10:46 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I sold one for $100 just last year at a local swap meet....I thought I priced it to cheap as it sold 5 minutes after putting it out?
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: Dcuda69] #1271470
07/21/12 10:48 AM
07/21/12 10:48 AM
Vancouver,Canada
Vancouver,Canada
I figured they were a bit hard to find so 100$ wouldn't have been to nuts...the hunt is on
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: 70 Roadrunner*] #1271471
07/21/12 10:52 AM
07/21/12 10:52 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Ebay !!!
They pop up every once in awhile - But look for stripped threads or heli coils on the carb mounting threads , to find a mint one might bee a stretch and then of course cost
I guess i dont understand everyones dedication with these intakes when they only put out at best , maybe and i mean maybe a few more hp then the newer Edelbrock Performer Intake
Of course the Performer RPM is a different animal but hood clearance always comes into play
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: 70 Roadrunner*] #1271472
07/21/12 10:54 AM
07/21/12 10:54 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
If you already have a stock late 60's-early'70's 4bbl. intake, the
DP4B will not make your car faster. I've been there done that 30yrs
ago.
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: 70 Roadrunner*] #1271473
07/21/12 11:09 AM
07/21/12 11:09 AM
scratchnfotraction Offline
you might look at an weiand action plus intake. its old skool like the dp4b but a little more performance same hieght as a stocker/dp4b from the looks of it.
i run one on my stock 78 440 with a 600 carb, kinda going opposite of you though,i am looking to poke one thru the hood.
another option might be a old skool holley street/strip dominator,they are a low rise single plane,spredbore intake that works rather well on the street for a single plane intake,IMO.
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: scratchnfotraction] #1271474
07/21/12 11:11 AM
07/21/12 11:11 AM
tboomer Offline
tboomer  Offline
What Scratchy says!! Much better intake!!
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: Dan Halen] #1271475
07/21/12 11:32 AM
07/21/12 11:32 AM
Finland
CarelianCuda Offline
Finland
Actually it's Dodge Plymouth 4 Barrel (for 383-400) and CH4B is Chrysler 4 barrel (for 413-440).
Not bad at all by test results:
http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/viewall.html
1970PlymouthCuda383
1970AMCHornet2D232
2003TruckmastersOkenosDurangoSlt+
2008DodgeChallengerSRT8
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: tboomer] #1271476
07/21/12 11:32 AM
07/21/12 11:32 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Yep! I use the Holley on the 383 I just built for my ride.
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: Dan Halen] #1271477
07/21/12 11:39 AM
07/21/12 11:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This intake won't fit under his N96 hood without cobbling up an expensive air cleaner, so even though its a better intake it's not fitting his criteria. One advantage the DP4B has over the stock iron itake , it's 20lbs lighter.
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: JohnRR] #1271478
07/21/12 12:22 PM
07/21/12 12:22 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'm looking for a DP4B for my 70 D100, I want it instead of the Performer or SD (which I have) strictly because I want the truck to look as it would have in 1970. I agree on the $75-$100, I'm waiting for one at a swap meet so I don't have to pay the shipping/border fees.
Sheldon
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: RUNCHARGER] #1271479
07/21/12 01:17 PM
07/21/12 01:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I used on on my 69 Runner back in the day that was other wise completely stock and it made pretty noticeable difference in ET and MPH.
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: MoparforLife] #1271480
07/21/12 02:00 PM
07/21/12 02:00 PM
dart1962_440 Offline
I heard the DP4B is taller than a stock 4bbl intake - is this correct? Anyone have the heights of the various intakes being discussed above?
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: dart1962_440] #1271481
07/21/12 02:37 PM
07/21/12 02:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it's taller it in not by much as I used it on a 383 in my 1969
Superbee with N96 hood and a factory air cleaner assembly that was not modified in anyway, no problems.
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: MoparforLife] #1271482
07/21/12 03:13 PM
07/21/12 03:13 PM
RUNCHARGER Offline
RUNCHARGER  Offline
I agree the DP4B is better than stock, more so than the Performer.
Sheldon
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: dart1962_440] #1271483
07/21/12 05:20 PM
07/21/12 05:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
About 0.4"
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: BSB67] #1271484
07/22/12 02:18 AM
07/22/12 02:18 AM
Vancouver,Canada
Vancouver,Canada
A few of my reasons to go to this manifold is yes,it's aluminum and much lighter than the cast iron stock manifold.Further it accepts a square bore carb if I'm not mistaken and this will allow me to run a Holley 750 DP carb.It probably has a bit better performance than the stock manifold.Lastly it will fit with my N-96 Air Grabber hood...if I'm wrong someone please tell me.If there's a better manifold that will fit my car I'll go with that but from what I've been able to determine the Dp4b intake will cut weight and improve performance...it's a start
Re: Edelbrock Dp4b intake-how rare are these and where can [Re: 70 Roadrunner*] #1271485
07/22/12 02:31 AM
07/22/12 02:31 AM
RUNCHARGER Offline
RUNCHARGER  Offline
You've got it all right. I agree with all the reasons you stated.
Sheldon
