18 Spline Clutch Disks #127145
09/27/08 03:50 PM
09/27/08 03:50 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Where can I get the correct 18 spline, 10 1/2" clutch disk for my 70 Charger? It's a street driven car mostly. I want a good quality piece and I have checked with Summit, but all they show is 23 spline 10 1/2" disks, and 18 spline 11' disks. My local stores sell brands that I have never heard of, so I'm leary of those.
What have some of you purchased?
THanks,
Re: 18 Spline Clutch Disks [Re: 3_RTs] #127146
09/27/08 04:49 PM
09/27/08 04:49 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The "correct" clutch disc for an 18-spline '70 would be 10.95".
If you actually need a 10.5" disc try MP P4529138.
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=761
Re: 18 Spline Clutch Disks [Re: John_Kunkel] #127147
09/27/08 05:24 PM
09/27/08 05:24 PM
Texas
amchale Offline
amchale  Offline
Texas
RAM clutches actually make components to use either 23 or 18 spline trannys with any of the pressure plate sizes in case you want to mix and match differently than what the factory used.
http://www.ramclutches.com/Applications/dodge.htm
Re: 18 Spline Clutch Disks [Re: John_Kunkel] #127148
10/03/08 09:27 AM
10/03/08 09:27 AM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thanks, John, so what would be the correct size flywheel for my car. Currently, I have a 130 tooth flywheel using a clutch disk that measures 10.5" diameter. Do I have the wrong flywheel for my car? I just want the stock setup.
Re: 18 Spline Clutch Disks [Re: 3_RTs] #127149
10/03/08 09:37 AM
10/03/08 09:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No the 130 tooth wheel is correct . you need the proper SCALLOPED pressure plate for the 10.95 disc .
Re: 18 Spline Clutch Disks [Re: JohnRR] #127150
10/03/08 09:42 AM
10/03/08 09:42 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
There are alot of option out there for the 10.95 on the 130 tooth fly.
It fits very nice and snug....and yes JohnRR I removed the two other green tabs
This is a McLeod obviously.
Re: 18 Spline Clutch Disks [Re: quick77rt ] #127151
10/03/08 10:52 AM
10/03/08 10:52 AM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thanks, guys, for the info. I've been using a 10.5 clutch disk and a pressure plate for a smaller motor all this time.
Jerry
