408 stroker #1271311
07/20/12 09:50 PM
07/20/12 09:50 PM
Jackson Michigan
67barrracuda Offline OP
Jackson Michigan
I have a 408 stroker 360 that is exturnally balanced. If I switch the harmonic balancer, do I need to have the motor rebalanced? What if I keep the same flex plate and neutrally balanced torque converter?
Jackson Michigan
Re: 408 stroker [Re: 67barrracuda] #1271312
07/20/12 10:35 PM
07/20/12 10:35 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
If the balancer is external you are good to go, if it's internal balance...You will need to get the motor balanced and use a neutral balance flex plate.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 408 stroker [Re: 67barrracuda] #1271313
07/30/12 05:52 PM
07/30/12 05:52 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
So long as the balancer was a stock balanced for external balance 360 that you are using with the stroke package, you should be able to swap it without issue. Should be easy to tell by looking at the it for the offset lobe on it for the external balance design.
Re: 408 stroker [Re: Alikazam] #1271314
07/31/12 12:10 AM
07/31/12 12:10 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
the rotating is balanced with the harmonic balancer...unless it was with a neutral one, you will need to have it balanced
Re: 408 stroker [Re: Wedgeman] #1271315
08/03/12 11:55 AM
08/03/12 11:55 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Only if they did modifications after a "stock" balanced for external. Its not a bad idea to get it all rebalanced, but not 100% necessary assuming whatever you put on there is by a company that does things to spec and has good quality control. And that the people who balanced your engine didn't actually touch the stock external balanced style harmonic balancer that you had on there before.
