converting...well, for this one anyway! #1270877
07/20/12 01:08 PM
07/20/12 01:08 PM
Out of the State of Confusion
blue_stocker Offline OP
Well, this is different and certainly should be interesting! I've been around the MOPARTS forums since the very early days but have been (so-to-speak) stuck in the drag racing 'groove'. Having been a drag racer (stock & super stock since '71), and not being able to sell this car as it was, it's being converted to street-duty, and up-to-this-point has been an intersting and somewhat disappointing adventure, but that seems to be changing. All of the hard-core racing parts and suspension have been removed/sold and the 'tamer' street-type components have begun to appear, BUT...the competitive spirit seems to have raised it's ugly little head once again; you know, the one that wants to twist the wheel under power, so I could be in a heap a trouble here too!
So wheel-twisters, here's what I've got and here's what I need from this 'handlers' forum: a good handling package for this old 1971 B-body. As it sits, the car's a former stock eliminator drag car, frames tied (quite well), 8 pt roll bar (a new mild steel cage in the basement, oh oh!), new 1.03" torsion bars, LCA stiffener plates, torque boxes, removed the D60 and am currently building an 8-3/4 w/powr-lok and after-market axles, looking at 16x8 steel wheels and Z-rated Falken 255-50-16 tires. Since this will be a 'street car' I opted to NOT go the 'pro street' route as I want good handling not insanity with the real 450-475 hp 440/4 spd that should give adaquate performance. You may have noticed I didn't fill in the suspension blanks, that's where y'all come in. BTW being as I DO like to lean on the loud pedal, there's a good possibility this old girl will see the likes of Thunder Hill and maybe some autocross action, so by-all-means, add your .02! Thanks...wb
Re: converting...well, for this one anyway! [Re: blue_stocker] #1270878
07/20/12 01:17 PM
07/20/12 01:17 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Nice Car I think that you can start out with the basics and then change things as you test and tune. I would have left the 60 and just put in a power lock, I perfer the stoutness of it. Good luck with your project. Tim
Re: converting...well, for this one anyway! [Re: blue_stocker] #1270879
07/20/12 01:22 PM
07/20/12 01:22 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
The 8pt cage ---it's a NOT roll bar--- would be fine if you take out a bar or two, and put in the proper bars for corners. How many attach points on the new cage?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: converting...well, for this one anyway! [Re: astjp2] #1270880
07/20/12 01:26 PM
07/20/12 01:26 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
1 1/4 tubular front sway bar
adjustable rear sway bar
offset upper control arm bushings for 3-5 degrees caster or tubular control arms. Depending on budget.
Brake upgrades on that heavy car. Budget and objective dependent. I'd think 11.75 big rotors at minimum.
Bilsein shocks.
some type of rear spring that will bring the rear down and have a strong front segment: like a Firm Feel circle track or Hotchkis setup.
...just off top of my head.
Re: converting...well, for this one anyway! [Re: autoxcuda] #1270881
07/20/12 04:42 PM
07/20/12 04:42 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
My car was initially a street/strip bracket car with everything that went with that except a cage. My first couple upgrades were some RMS control arms and a fat Hotchkis swaybar along with swapping drag shocks for some Monroes. I have been hooked ever since, which was only last year. I have done a ton of other stuff since then as well and it keeps getting better and better.
Mopar to the bone!!!
Re: converting...well, for this one anyway! [Re: amxautox] #1270882
07/20/12 05:13 PM
07/20/12 05:13 PM
Thanks for responding guys. As for the 'roll bar', yes it IS a roll bar w/hoop, side bars and 2 rear bars intersecting in the trunk and 2 more extending from the cross bar of the hoop diagonally to the frame connectors=8 pt. The new cage is a 12 pt with bars connecting to the front longitudinals to the A-pillars, the A-pillar bars, an under-dash bar and one tube connecting the overhead to the A-pillars, side bars, the rear 'X' from the hoop to the rear shock towers and trunk bars so it should make the triangulation substantial.
The D60 IS stronger but the reality is sprung/un-sprung weight and since the car's not really needing that much additional strength (from the brute force of a 6500 rpm static launch in a drag car), the 8-3/4 should do well and have the added bonus of quick gear changing at the track, if needed. I am planning on poly bushings and some Firm Feel components but am not sure which direction to go with shocks?! Being a little 'overkill' oriented, I admit I must be a little more conservative but that balance point is new to me...HA!
Re: converting...well, for this one anyway! [Re: blue_stocker] #1270883
07/20/12 05:31 PM
07/20/12 05:31 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
To bring the rear end down go with a Mopar XHD leaf spring. (Get two left side springs) as to have the same spring rate on both the left and right side. Just like the T bars have with the same diameter.
To help lower the car get the front leaf hangers from Firm Feel they have a factory attachment point for stock height and the Higher bolt hole location to lower the car approx. 1" maybe more.
Here is a picture of my 72 RR with the same rear leaf spring set up above mounted in the lowering location, 16 x 8" wheels with 0 offset and 4.5" backspace from Vintage Wheel Works and the same size tires you mentioned 255/50R16 from BF Goodrich G Force Comp 2 ($136 each from tire rack)
We dumped the 4:30 gears in favor of a 2.94 sure grip center in the 8 3/4" out back.
Re: converting...well, for this one anyway! [Re: blue_stocker] #1270884
07/20/12 06:02 PM
07/20/12 06:02 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
The simples, easiest, best bang for the buck would be to pick up the XV Level 1 kit. It is $2250 for new t-bars, springs, front and rear sway bars and rate matched shocks.
If you want to build it in sections as time/money are available and retaining some of your current parts, then the Hotchkis TVS set up is a nice package that can be purchased individually with an end goal that they will acheive. Overall will run you around $2500, give or take depending on your source for buys.
Either of these get you in the game without the need to dig into analysis of what works well together, what are good mods vs great mods vs incremental mods, or the headache of parts that don't play well together.
Re: converting...well, for this one anyway! [Re: TC@HP2] #1270885
07/21/12 01:56 AM
07/21/12 01:56 AM
Thanks for the heads-up Tony. While browsing the XV page I noticed some interesting tid-bits which opened up enough of my thinking skills to ask a ton of questions so some phone calls to Firm Feel, XV and Hotchkis are in order. THANKS again, much appreciate! BTW, nice stance on your RR, Paul, looks great!
Re: converting...well, for this one anyway! [Re: blue_stocker] #1270886
07/21/12 02:16 AM
07/21/12 02:16 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Since you already have some parts like the 1.03" T bars I would just keep those and concentrate on the other parts you might like.
Don't overlook Firm Feel for their comprehensive list of parts and steering boxes etc etc. They might not have a kit listed like XV and Hotchkis but they have been in the Mopar handling business many years. Call Dick at FF excellent guy to bounce your ideas off of and get his opinion.
Re: converting...well, for this one anyway! [Re: blue_stocker] #1270887
07/21/12 02:26 AM
07/21/12 02:26 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You might want to read this before spending any money with XV
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: converting...well, for this one anyway! [Re: 1_WILD_RT] #1270888
07/21/12 04:06 AM
07/21/12 04:06 AM
Thanks for THAT heads-up Randy, I sure don't need to be dealing with some mfg or vender that produces shoddy parts or get caught-up in some stinking drama, got too much of that...'elsewhere'! HA! Looks as if the straight-ahead method is the simplest and the best...I'll call Firm Feel and Hotchkis and leave the over-priced/glorified trinkets alone. Since the drag race chassis parts have been removed and sold I'm all ears for particular parts combinations, springs/shocks/sway bars/etc. I'd actually like to drop the car another 1-2" from the ride height of Paul's '72 runner, make it level and sling through the turns like the yellow Hotchkis '70 Challenger, I like that! Thanks again for the info guys, much appreciate...wb
Re: converting...well, for this one anyway! [Re: blue_stocker] #1270889
07/23/12 04:52 PM
07/23/12 04:52 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
if you want a great deal on tubular adjustable sway bars for our runners - this is what i found, you can't beat the price!
http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=16954
http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=10105
Re: converting...well, for this one anyway! [Re: dangina] #1270890
07/23/12 06:21 PM
07/23/12 06:21 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Thanks for the tip, Just ordered the tubular 1 1/4 for $150, ($161.20 shipped). I wanted a Hotchkis, but this should do until I'm rich. I contacted them again and they lowered the shipping $10 or so. So that should make it $151.20 to match or beat Amazon.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: converting...well, for this one anyway! [Re: dangina] #1270891
07/23/12 06:31 PM
07/23/12 06:31 PM
Hmm, yes pretty interesting, and the price IS hard to beat. Front & rears look pretty good and just what I'm looking for; thanks for the heads-up, much appreciate!
Re: converting...well, for this one anyway! [Re: blue_stocker] #1270892
07/23/12 09:33 PM
07/23/12 09:33 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That link lists the tubular bar for 71-72, but the 1970 models should have been included since they are the same. I wish that they would have listed the wall thickness. That really helps determine if it is any better than a 1 1/8" solid. Weight savings is nice, but if the performance is a step backwards , then where is the benefit?
Re: converting...well, for this one anyway! [Re: Kern Dog] #1270893
07/23/12 11:28 PM
07/23/12 11:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I usually just google the Hellwig part # and see what comes up. I think I paid $140 shipped for my Hellwig rear bar.AMAZON rules......
Re: converting...well, for this one anyway! [Re: dangina] #1270894
07/24/12 12:13 AM
07/24/12 12:13 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Thanks! I just got f/r Hellwig bars for my Barracuda for 301.96 including shipping.
Re: converting...well, for this one anyway! [Re: Kern Dog] #1270895
07/25/12 01:04 PM
07/25/12 01:04 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I've never had a '70 B body to verify, but as a transitional year, I thought late production year models MAY be able to use the 71+ bar, but might, depending on the pass through in the K frame, may be required to use the '69 and older bar, especially in early production year versions.
This is an important distinction as the pre '70 bar has much longer arms than the post '71 bar and will have differing applied rates between the two, even if they are the same diameter material.
I guess bottom line is if you have a '70, you'd better verify. In wb's case, his car is a '71 so it will use the short arm version like those found in E bodies. So, since I haven't shopped tubular anti -bars, is their a diameter difference between the cut off years as I've seen guys on here talking about 1.38" and 1.25" tubular versions.
Re: converting...well, for this one anyway! [Re: Kern Dog] #1270896
07/31/12 11:25 AM
07/31/12 11:25 AM
I called Hellwig Monday morning and talked to an engineer who claimed these 1-1/4" front tubular sway bars have .180" wall thickness, if that helps at all.
