Page 2 of 3 1 2 3
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: roadhazard] #1270853
07/20/12 07:15 PM
07/20/12 07:15 PM
Out in Left Field, NY
bobs66440 Offline OP
"Who Has a Big Block That DOESN'T Leak, Show of Hands"
448" in the Barracuda
and
440" in the Charger
No leaks anywhere Then again some think I have an unfair advantage
What did you use to lubricate the crank & seal with?
I used standard red grease, Valvoline or similar I think.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270854
07/20/12 07:26 PM
07/20/12 07:26 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
none of my big blocks have leaked in years.
Haven't run in years either.
Show of hand(?)
I have mechanical Aptitude.
I can screw up anything.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: JohnRR] #1270855
07/20/12 07:27 PM
07/20/12 07:27 PM
With that in mind and the origin of this engine if it truly is leaking past the head gasket you may not get it to stop , Cometics require a certain surface finish on both the head and the block to seal properly , following your build up I don't think I saw this taken into account? Did you put some type of spray sealer on the gasket?
If Cometic says to retorque then you're going to have to bite the bullet and do it .
I didn't use any sealer as per their instructions. The Cometics require a very fine grit finish to seal (50 Ra or finer). The Stealth heads were as they come new. I looked into it at the time and I remember their finish being compatible.The block was very smooth. Not sure of the Ra but it was what I would estimate a finish after sanding with 1000 grit or so. Definitely smoother than the heads.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270856
07/20/12 07:40 PM
07/20/12 07:40 PM
New State
kidmopar Offline
kidmopar  Offline
New State
1970 440 Sixpack 200 miles = NO LEAKS!
1971 383 Challenger 118k NEVER been out of car! = few drippy-drops
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270857
07/20/12 10:33 PM
07/20/12 10:33 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
And now that I did that, I just jinxed myself and everything will start leaking like a sieve tomorrow.
Rich H.
Esse Quam Videri
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270858
07/21/12 12:25 AM
07/21/12 12:25 AM
ScatPackNick Offline
No leaks on my 440, had it since 2000
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: ScatPackNick] #1270859
07/21/12 08:18 AM
07/21/12 08:18 AM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
rebuilt engin with 1200 miles .... no drips anywhere...
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: 72ls5fla] #1270860
07/21/12 08:26 AM
07/21/12 08:26 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Two,finished bird in 92,never leaked a drop,wagon a year ago,800 miles,same thing.Used O.E.M.seal's in both,use the correct stuff,do it right and you should not have a problem.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270861
07/21/12 10:59 AM
07/21/12 10:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
mine does leak after a year and a half..of course now that I said it there will be a big mess next time out.
Coming soon!!!!
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270862
07/21/12 12:17 PM
07/21/12 12:17 PM
Texas
racer_amx Offline
racer_amx  Offline
Texas
No problems with my 440 so far
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270863
07/21/12 12:29 PM
07/21/12 12:29 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I have three of them with no leaks two 496 and a 511.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270864
07/21/12 12:45 PM
07/21/12 12:45 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
and
440" in the Charger
I can't say if that was your problem or not without inspecting the seal. However, I use and recommend Clevite Bearing Guard, Torco, Redline or equivalent liberally on the seal and crank.
My motto; Treat the seal as if it were a bearing.
It actually takes a long time for oil to migrate back to the rear seal area. Without plenty of lube it can cause a dry running condition that can damage the seal lip.
There are many areas that can also leak. Such as the base of the seal retainer not fitting properly on the block, retainer side seals, improper alignment of the two seal halves and I've seen the rear cam plugs weep oil that also look like a rear seal leak.
Hope you're able to track down exactly what the cause is
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: roadhazard] #1270865
07/21/12 03:12 PM
07/21/12 03:12 PM
and
440" in the Charger
I never thought of the cam plug. It's odd because after I shut it off and it sits a while, there's really no oil dripping from the rear main area. It's all up inside the bell housing and eventually drips down the sides. I just assumed that it's coming out of the rear seal and getting flung around. Now that I think of it, I've had a few rear mains leak and they have always dripped from the rear main area. I'll have to look closer. Thanks.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270866
07/21/12 03:37 PM
07/21/12 03:37 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My first 440 leaked from the bellhousing area. I pulled the pan twice to replace the rear seal and side seals. I later found the problem to be the rear oil gallery plugs. They weren't tight enough!
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: Kern Dog] #1270867
07/21/12 04:06 PM
07/21/12 04:06 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Oil pressure sender is EZ to check.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: Kern Dog] #1270868
07/21/12 06:19 PM
07/21/12 06:19 PM
That's a good thought also. The more I think about it, it almost seems like it needs to be coming from the top to get flung around by the flywheel like that.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270869
07/21/12 10:32 PM
07/21/12 10:32 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I really don't consider them to be leaks.
I think it's just "sweat" from all that horsepower!
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: jcastle1] #1270870
09/06/12 01:37 PM
09/06/12 01:37 PM
Just an update.
It turns out that the leak is coming from the front of the trans (A-833) Probably from the front bearing retainer. While I'm glad it's not the engine, it's a leak nonetheless and I HATE leaks.
The ironic thing is that I just had the previously non-leaking trans rebuilt ($800) due to shifting problems, and it turned out to be the shifter instead (my fault). So I spent $800 for an oil leak!
I can take it back and he would probably fix it no charge, but it's running and driving so good that I'm afraid to let him screw around with it...and I don't want to pull it myself...
It looks like the fill hole is about even with the bottom of the retainer, which would explain why it leaks only when it's running and not while its sitting. The oil is probably splashing up and out. I wonder if it will slow down once the level gets down a little. But I don't want to run it low on fluid...crap.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270871
09/06/12 04:10 PM
09/06/12 04:10 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Bob the oil is flying everywhere when it's running so the only way the oil will be below the retainer is at rest with the engine not running.
Another leak point is the cluster gear pin. My 833 leaks there but I used the pin for an OD trans which is shorter than the NON od 833 . I cleaned it and filled the cavity with RTV, when I can I will pull it back apart and put in the right pin, with some type of sealer in the hole first.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: JohnRR] #1270872
09/07/12 07:36 AM
09/07/12 07:36 AM
Thanks John. I suppose the right way to do it is yank it back out. I knew that I guess. No magic bullet...I'm just terrified of letting someone tear it apart. Oh well, it is what it is.
Page 2 of 3 1 2 3
