Page 1 of 3 1 2 3
Who Has a Big Block That DOESN'T Leak, Show of Hands #1270833
07/20/12 12:36 PM
07/20/12 12:36 PM
Out in Left Field, NY
bobs66440 Offline OP
After break-in and for a few hundred miles on my new engine (my own build), it was completely dry. Not a drop on the floor! I was so happy. Now it's starting to leave quarter to half-dollar sized spots on the floor. I just don't understand why it would change suddenly.
I'm pretty sure it's coming from the rear main as it's pretty wet inside the bell housing. It looks like the oil is getting flung around inside and then dripping down the sides.
I spent SO much time and care to get the rear main just right when I built the engine because I HATE oil leaks, and I heard how difficult it is to get one to not leak. The really frustrating thing is, the old engine I pulled out didn't leak at all, but it burned a quart in 200 miles...
Is there anyone with a dry engine??
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270834
07/20/12 12:42 PM
07/20/12 12:42 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Troy was battling rear main seal issues that he solved. I know someone else that was having the same problem and solved his the same way too. Both were aftermarket stroker cranks. Read here:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270835
07/20/12 12:43 PM
07/20/12 12:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Me, so far so good. Bult the engine myself in 2005 and no leaks yet. Don't have alot mile though, maybe 1000.
What kind of crank and retainer are you using?
My 340 don't leak either...
All factory stuff used on my rebuilds.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: Challenger 1] #1270836
07/20/12 12:50 PM
07/20/12 12:50 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Including rope seals on the rear main ?
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: JohnRR] #1270837
07/20/12 12:52 PM
07/20/12 12:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: Challenger 1] #1270838
07/20/12 01:10 PM
07/20/12 01:10 PM
U.S.S.A.
U.S.S.A.
Is the tool for setting the seal still available ?
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: JohnRR] #1270839
07/20/12 01:20 PM
07/20/12 01:20 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
There's no oil on the concrete where my 451 lives, built in 06 and not many miles a thousand or 2 at most. Used the rubber rear seal that comes in a Felpro gasket set.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: Challenger 1] #1270840
07/20/12 01:43 PM
07/20/12 01:43 PM
It's a factory steel crank and 440Source main cap. I read through all the posts regarding this from the past (including all the warnings, etc) and double/triple checked everything to death. As I said, it was totally dry, and I thought I had it beat, but now it's leaking. It also appears to be seeping a little from the head gasket (Cometic MLS) on the driver's side. I spoke to their tech line and they said to try to re-torque the head.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270841
07/20/12 02:12 PM
07/20/12 02:12 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Just went through the same issues. Built 512 stroker with 440Source kit, Mancini retainer. Replaced the rear main twice after the build due to bad leak at the right rear area. Ended up being the oil pan! New pan that would "rock" on a flat surface. Could even see light from under pan. (put a flashlight under pan on flat surface). Spent about an hour with a board, hammer & dolley to get flat again! So far - so good! Seems like everyone I talk to that has a Mopar has trouble getting the engine to seal! Sometimes ya just gotta be lucky! Jeff
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270842
07/20/12 02:34 PM
07/20/12 02:34 PM
U.S.S.A.
U.S.S.A.
Oil from the head should NOT be in the bellhousing but stranger things have happened. I'd be looking at the main seal first.
It's also interesting that you have oil leaking from a wedge head , the only place oil passes thru the headgasket is for the oil to the rockers and that would leak back into the valley ???? Are you sure it's not the valve cover leaking or your intake valley pan ?
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: JohnRR] #1270843
07/20/12 02:42 PM
07/20/12 02:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: JohnRR] #1270844
07/20/12 02:54 PM
07/20/12 02:54 PM
I know the main leak isn't coming from the head. I just added that as an additional complaint (I know I'm whiny lol). I checked really good all around the valve cover and it's completely dry. Also checked the intake pan gasket and the oil pressure sending unit. It's definitely coming from the head gasket unfortunately. I did a search and it seems it's not that uncommon with the Cometics.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270845
07/20/12 03:45 PM
07/20/12 03:45 PM
U.S.S.A.
U.S.S.A.
If it were a Hemi I could see it because there are oil drainbacks on the bottom corners.
Ok the stupid question , why did you use cometics on that engine ?
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: JohnRR] #1270846
07/20/12 04:16 PM
07/20/12 04:16 PM
Because they offered the thinnest gasket (.027" compressed) I needed for my build to get the compression ratio close to what I wanted. They work (supposedly) well with the aluminum heads and a bonus is they don't need to be re-torqued. Of course this situation may shoot that theory down...
Re-torquing the head would involve raising the engine a few inches to get the header off. Not a project I really want to tackle right now...
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270847
07/20/12 05:07 PM
07/20/12 05:07 PM
U.S.S.A.
U.S.S.A.
With that in mind and the origin of this engine if it truly is leaking past the head gasket you may not get it to stop , Cometics require a certain surface finish on both the head and the block to seal properly , following your build up I don't think I saw this taken into account? Did you put some type of spray sealer on the gasket?
If Cometic says to retorque then you're going to have to bite the bullet and do it .
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: JohnRR] #1270848
07/20/12 05:23 PM
07/20/12 05:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No oil leaks at all with my 493. My old 440 did drip a little at the rear main after a while. This eng I used the Hughes crank seal retainer and I have no leaks anywhere. Ron
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: 383man] #1270849
07/20/12 05:52 PM
07/20/12 05:52 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
My Hemi and 440 were always dry, when i owned them.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: hemi71x] #1270850
07/20/12 06:25 PM
07/20/12 06:25 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
"Who Has a Big Block That DOESN'T Leak, Show of Hands"
448" in the Barracuda
and
440" in the Charger
No leaks anywhere Then again some think I have an unfair advantage
What did you use to lubricate the crank & seal with?
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: bobs66440] #1270851
07/20/12 07:00 PM
07/20/12 07:00 PM
fullmetaljacket Offline
Dry spell here, just a little sweat on the sides of which I clean up every now and then.
Re: Who Has a Big Block That DOESN'T Leak, Show of Hands [Re: roadhazard] #1270852
07/20/12 07:07 PM
07/20/12 07:07 PM
NJ
rth Offline
rth  Offline
NJ
I get some seepage from oil pan gaskets. My rebuilt p/s pump also weeps from can.
Page 1 of 3 1 2 3
