Re: vibration update on the cuda
#127064
12/04/08 03:54 AM
12/04/08 03:54 AM
Posts: 912 London, England
mopar_mark
London, England
Almost time to hire a Vibration Analyst.
Dan, I can get one of those from my new 8.50 index car's sponsor "CHEERLEADERS". Many girls there have a PHD in that field
Batteries not included
[Re: mopar_mark]
#127065
12/04/08 08:42 AM
12/04/08 08:42 AM
i got the hookup on the batteries. Tell me where to bring them and I'll hand them off personally
#127068
12/04/08 12:03 PM
12/04/08 12:03 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Personal Handheld Device?
Post deleted by Defbob
[Re: cudadan]
#127069
12/04/08 02:11 PM
12/04/08 02:11 PM
#127070
12/04/08 03:26 PM
12/04/08 03:26 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Fred, don't you have to pass the test [find the problem and fix it} before you get the certificate?
#127071
12/04/08 08:49 PM
12/04/08 08:49 PM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
ROFLMAO, now this is getting good
omg Fred you are killing me, well i am thinking that its the motor i clamped a pc of Aluminum all over the underneath of the car and at the rear it barely moved when i got closer to the motor it was springing like a diving board from the tranny forward
[Re: David_in_St_Croi]
#127073
12/04/08 10:50 PM
12/04/08 10:50 PM
cudadan
Stratford nj
Have you checked the condition of the harmonic damper?
brand new and does the same as the old one lol, i am gonna try a new flex plate just for the hell of it
[Re: RemCharger]
#127075
12/05/08 02:01 PM
12/05/08 02:01 PM
cudadan
Stratford nj
If it was in the motor /front trans area, wouldn't it vibrate with engine rpm and/or in nuetral?
it do feel some vibes but not as bad, but when you sit in the car in 3rd gear 35mph @1800 it feels like your teeth are gonna fall out of your head, when you go under the car and feel the rear housing, you can barely feel it, go to the trans mount area shaking like shakes more than an 1/8. it is so bad.
[Re: cudadan]
#127078
12/05/08 08:05 PM
12/05/08 08:05 PM
RemCharger
Sk. Canada
I had a cast crank 440 with steel balancing stuff on it. I've got a 383 with a shimmy stemming from the convertor hub being out of whack. Both of those deals you could feel vibrations at 35 mph. BUT, you could, (and I did ) race them. They were fine as far danger goes, just not too good on the bearings. Both of them had the exact same vibes in nuetral as driving. Your deal has got to be at driveshaft speed . If you go under the car, how hard is it the physically move the pinion snout around?, pretty hard. Now try moving the rear of the tranny around, somewhat easier. If there is a d/s issue even at the rear, its going to start tossing the tranny around. Its hard to diagnose from 8 million miles away, but when you keep saying its scary at 80 miles an hour, I find it hard to believe its engine rpm related. You would know it in neutral...
[Re: SomeCarGuy]
#127080
12/06/08 01:53 PM
12/06/08 01:53 PM
cudadan
Stratford nj
Since you swapped out every other thing, I would think a motor swap would not be much more work at this point.
thats what im gonna do, im putting in a bad a$$ lil 340 to check, probably right after the holidays. 340 is for sale too.
[Re: cudadan]
#127082
12/15/08 05:14 PM
12/15/08 05:14 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
your going to sell a 340 ci vibrator?
do you have a pulley on the balancer?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: cudadan]
#127083
12/15/08 05:37 PM
12/15/08 05:37 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
sounds like you have a cracked flex plate or the wrong one . Strokers are balanced different than a non stroker engine . maybe converter issues ?
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!!
11.0's on pump gas .
