who knows carbs #1270357
07/19/12 09:14 AM
07/19/12 09:14 AM
NEW YORK
MAXEDWEDGE Offline OP
NEW YORK
i have two 750 carbs on my tunnel ram ,i would like to be able to put two 850 main bodies on the 750's metering blocks,base plate and bowls.Will i ever get it to run right ? what do you guys think
Re: who knows carbs [Re: MAXEDWEDGE] #1270358
07/19/12 10:37 AM
07/19/12 10:37 AM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
I think the biggest issue would be the base plate. I had an 830 holley one time which is a 1000cfm main body on a 750 base plate, but the base plate was beveled out to match the diameter of the venturi. I would think that having the bottom of the venturi much larger than the throttle blades wouldn't work well unless you were to machine the base plates to match.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: who knows carbs [Re: DconD100] #1270359
07/19/12 10:49 AM
07/19/12 10:49 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I would just go ahead and put 850's on it if I had to have the extra cfm's. I don't know the size of your engine,but if not to big the 750's DP with the airhorns milled off,PV plugged and sq jetted @ 80 will work great.Set your idle screws @ 3/4 turn's and adjust your idle speed to that.
Hope this helps and saves you a little $$$.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: who knows carbs [Re: MRMOPAR622] #1270360
07/19/12 10:53 AM
07/19/12 10:53 AM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Like D100 said theres a 1.720 bore in the 750 body/baseplate and a 1.750 bore in the 850 body so theres going to be a visable step....but the biggest problem is the 750 and 850 have the idle circuits in different spots in the baseplate and it will not idle/work....you would need a baseplate and body from 850's....Jesse
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: who knows carbs [Re: BIGS] #1270361
07/23/12 10:47 AM
07/23/12 10:47 AM
NEW YORK
NEW YORK
Thanks to all
Re: who knows carbs [Re: MAXEDWEDGE] #1270362
07/24/12 07:18 AM
07/24/12 07:18 AM
NEW YORK
NEW YORK
I always thought that on a daul carb , that the carbs where set up much different ftom a single carb. application
