Trans brake wiring ? #1269537
07/17/12 02:04 PM
07/17/12 02:04 PM
Muskegon Mi
dcr Offline OP
dcr  Offline OP
Muskegon Mi
Recently installed my new tranzact 727 with a ultimate brake and having trouble getting a hold of Joe to ask what gauge wire I should use. I currently have it wired with 14 ga wire is this sufficiant?
Re: Trans brake wiring ? [Re: dcr] #1269538
07/17/12 02:23 PM
07/17/12 02:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Should be fine, that's what we used on ours. What kind of a two step are you running? Although with ours I ended up using a relay for the two step, the trnas brake itself has never needed a relay to it.
Re: Trans brake wiring ? [Re: Dragula] #1269539
07/17/12 10:12 PM
07/17/12 10:12 PM
Muskegon Mi
dcr Offline OP
dcr  Offline OP
Muskegon Mi
Thank you for info Im useing a MSD 2 step no relays on any thing I would think they would be a low current draw and not require a relay.
Re: Trans brake wiring ? [Re: dcr] #1269540
07/17/12 10:35 PM
07/17/12 10:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most trans brakes dont draw alot so 14 gauge is fine
