Re: keyway lifters
[Re: LSP]
#1268994
07/16/12 11:14 PM
07/16/12 11:14 PM
Posts: 6,151 Melbourne , Australia
LA360
Apart from the old Crower units that used a couple of ball bearings and supplied a fixture, I would imagine it would be tricky machining the grooves accurately. Unless you could do it yourself, I would imagine it would be an expensive exercise.
Alan Jones
Re: keyway lifters
[Re: ahy]
#1268997
07/16/12 11:32 PM
07/16/12 11:32 PM
bigbee
Really? You can pull out a lifter bushing and replace it? I mean can you correct a problem created by lifter bushings, such as too small of oiling holes or if you damage a lifter bushing, can it be replaced?
Re: keyway lifters
[Re: bigbee]
#1269002
07/18/12 05:57 AM
07/18/12 05:57 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
nothing being done to correct lifter in the bore ??
keyways are a un needed cost for sure
home of the Sox and Martin Hemi Duster
Re: keyway lifters
[Re: Performance Only]
#1269004
07/18/12 07:00 PM
07/18/12 07:00 PM
LA360
Jesel Keyway lifters are around $2600 plus bushes and installation. Probably around $4K when all said and done. Most of the lifter companies will work with you on changing the link bars if they are proving to be a problem.
Alan Jones
Re: keyway lifters
[Re: HEMIFRED]
#1269005
07/19/12 06:13 PM
07/19/12 06:13 PM
Posts: 8,165 Left Coast
BobR
Left Coast
My engine builder won't use anything else for high end builds. I guess it depends on the budget and the build. They are the best lifter...hands down. If you don't need the best then they may be throwing money away.
