Re: will 18x10's fit on my 71 roadrunner?
[Re: roadrunner440]
#1268957
07/17/12 02:35 PM
07/17/12 02:35 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I have 18 x 10 WHEELS on the hot rod. There was room for 15 x 10 WHEELS on my 74 Road Runner too.
It's all about the backspacing.
[Re: roadrunner440]
#1268960
07/19/12 11:12 PM
07/19/12 11:12 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
18x10s all the way. Move the springs in, get the offset right and it's good.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: dfsmopars]
#1268961
07/20/12 07:45 AM
07/20/12 07:45 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
The Charger has more space than the Roadrunner. The combo i ran on my 72 Charger (15x8 steelie w 295/50-15) wouldn't work at all on the 72 Satellite, front or back. I figured they would. Disappointing... because it sure looked mean...
I should have known... as all those old Nascar Charger pics look pretty stock, metal-wise, where all the 71-2 Roadrunner pics have the wells cut out at the body line... a LOT ov missing metal.
Still... i can fit 18x10's easy on my 70 Challenger... which has to be smaller than a 71-2 B-body, even the smaller one? You should have no problems... just takes a LOT ov messing around, mocking up and finding the perfect backspace.
[Re: fiddlerfingers]
#1268964
07/20/12 11:11 PM
07/20/12 11:11 PM
Posts: 2,225 Silsbee,Tx
-Cuda
Silsbee,Tx
I'm running 20X10 on my 71 RR and there is plenty of room. No relocation of the spring mounts leaves about 3/8 inch between wheel and spring. Like stated above its all in the back spacing of the rim. I used a 4.5 inch back space.
Got pics? I'd think they'd work on my 73.
[Re: roadrunner440]
#1268965
07/21/12 12:16 AM
07/21/12 12:16 AM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
If you haven't heard back from me, you are probably not calling during business hours, or you are misspelling my E-mail address. doctordiff@gmail.com(406)883-4772 10-6 Mountain Time, M-F
