left offset or right offset rockers #1268573
07/15/12 10:40 PM
07/15/12 10:40 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
so my 440 ate up a couple of rockers and they are left right specific...question is how do they tell left or right looking down on r up from the bottom...I guess the drivers seat rule doesnt apply here. ill attach a pick i think they are left but want to be sure before I order them up
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: left offset or right offset rockers [Re: pnypwr] #1268574
07/15/12 10:41 PM
07/15/12 10:41 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
top side
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: left offset or right offset rockers [Re: pnypwr] #1268575
07/15/12 10:55 PM
07/15/12 10:55 PM
Looking at the top of the rocker the left rocker arm adjusters are offset to your left side, same on the right hand ones. Number one cylinder has a a right side rocker arm on the exhaust port and a left hand on the intake, # 3 cylinder is the opposite with the intake beig right hand and the exhaust is left hand, the adjusters are closest to each other in the middle regardless of cylinder numbers I would, and have, send those rockers back to Harland Sharp and ask them to repair them for you they have excellent service and they may rebuild or replace them for a very small service charge, maybe no charge
Re: left offset or right offset rockers [Re: Cab_Burge] #1268576
07/16/12 07:49 AM
07/16/12 07:49 AM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
theyre crane golds...summit has new ones for 25 each...
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
