Page 4 of 6 1 2 3 4 5 6
Re: 440, 4-speed, A/C ? [Re: TX9H6E4CUDA] #1268473
07/27/12 11:01 AM
07/27/12 11:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The police units cut the compressor out at full throttle, seems like something could have been done
Is this true? I have a compressior off a 1976 Monaco squad and would like to hook that feature up on my bee. Was it when the compressor hit a certain rpm it shut off and was this a internal feature?
It was not internal to the compressor but it's easy to do. All you need to do is add a switch to your throttle linkage that opens the line that engages the compressor clutch, which is what the factory did.
Re: 440, 4-speed, A/C ? [Re: 696pack] #1268474
07/27/12 02:27 PM
07/27/12 02:27 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Answering a few different things here.
1. Interesting. More research is required
2. Would a 440 over rev more than a 383? Not trying to be a jerk about this concept but everything that is mentioned about RPMs, gears and over reving a compressor with a 440... wouldn't the same thing have happened with a 383? Over reveing is over reving regardless of the CID.
.Page 98
Yes, the same thing would happen with the 383/335 and that is the reason for a 330 h.p. (lower reving cam) in an A/C Bee or RR. In fact, the 383/335 is actually a higher reving engine stock than the 440.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 440, 4-speed, A/C ? [Re: Commando1] #1268475
07/27/12 02:39 PM
07/27/12 02:39 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I'm not sure I understand your comment about the 74 cast/forged crank. Could you explain a little more?
All 440's 1974 and up had cast cranks but there are those who insist that they...
I know that parts books have mistakes. Are you saying the references to a forged crank in the 74 parts book is incorrect? They were never released? (Click on attachment for larger view)
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 440, 4-speed, A/C ? [Re: 69CoronetRT] #1268476
07/27/12 03:17 PM
07/27/12 03:17 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You are the FIRST person that has actually produced genuine documentation that says that it was. Everybody else just "swears" that...
Kudos
Re: 440, 4-speed, A/C ? [Re: DPelletier] #1268477
07/27/12 07:44 PM
07/27/12 07:44 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Guys, I'm really not trying to be a jerk about this. But what changed in 1970 when you could get a 335- horse four speed A/C car? Was the compressor redesigned for 1970? If it was redesigned to handle the 383HP engine, why couldn't the same concept be adapted to the 440?
Seeking:
Re: 440, 4-speed, A/C ? [Re: 69CoronetRT] #1268478
07/27/12 10:34 PM
07/27/12 10:34 PM
AZ.
696pack Offline
696pack  Offline
AZ.
Doug,
Per the 1970 Dodge Data Book it was NOT available with a 4 speed.
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Coronet0022.jpg
Re: 440, 4-speed, A/C ? [Re: 696pack] #1268479
07/27/12 11:47 PM
07/27/12 11:47 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Doug,
However, the 70 Coronet dealer price list says a/c "N.A. w/4 Spd on R/T". That sounds as if it was available on a Super Bee/383 car.
http://www.hamtramck-historical.com/images/dealerships/SalesmansPocketGuides/1970/70_Coronet0003.jpg
Looks like more confusion for us from Ma Mopar!
EDIT:
Just noticed the engine section at the bottom of the data book page shows no a/c for 440 4spd combo but no such restriction for 383 engines. That seems to agree with the price list info.
Re: 440, 4-speed, A/C ? [Re: 696pack] #1268480
07/28/12 01:25 AM
07/28/12 01:25 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Doug,
D, we know the data books are a pretty good resource but we also know there are mistakes and the books were updated. The combo was available in '70.
Seeking:
Re: 440, 4-speed, A/C ? [Re: JohnRR] #1268481
07/28/12 01:41 AM
07/28/12 01:41 AM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
Thanks John you come through again with great info
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: 440, 4-speed, A/C ? [Re: 69CoronetRT] #1268482
07/28/12 04:07 PM
07/28/12 04:07 PM
AZ.
696pack Offline
696pack  Offline
AZ.
Doug,
Yes, they were updated. Do you have an example of one that updated this combo becoming available?
I see you original FT example showing it which proves at least one was built. This comes full circle to the origin of this post regarding the availability of 440-4 speed-A/C. Althought you FT example is a 383 Super Bee but follows right along with this entire discussion/senario. That is a very heavily equipped Super Bee. The very kind of car we saw new that factory execs or their kids were driving. Could this have been one built for them with something NOT available per the Data Book or was the book changed so anyone could order it? Do you have any other examples of this being available?
Also regarding the "N" engine code in the V.I.N. there has always been confusion as to it true meaning as to h.p.
They made 3 different 383s but only show 2 different V.I.N. codes, 383-2 and 383-4. however we know that there are 2 different 383-4s, the 330 and 335 h.p. Without a B.S. you can never be sure how the car was actually built with regard to which cam it had. If you have the original untouched engine in the car that is a different thing but that is rare in these 40+ year old cars.
Re: 440, 4-speed, A/C ? [Re: 696pack] #1268483
07/28/12 07:09 PM
07/28/12 07:09 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Here's an interesting one...
Three speed A/C convertible
Seeking:
Re: 440, 4-speed, A/C ? [Re: 69CoronetRT] #1268484
07/28/12 07:22 PM
07/28/12 07:22 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Charger
Seeking:
Re: 440, 4-speed, A/C ? [Re: 69CoronetRT] #1268485
07/28/12 08:00 PM
07/28/12 08:00 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
71 Charger 500, 383 4-speed with A/C, 323's. 1 of 182.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 440, 4-speed, A/C ? [Re: 6T9Hemi] #1268486
07/28/12 08:12 PM
07/28/12 08:12 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
How about a '73 SSP with a 400 4-speed, A/C, and power windows?
Re: 440, 4-speed, A/C ? [Re: 69CoronetRT] #1268487
07/29/12 02:08 AM
07/29/12 02:08 AM
AZ.
696pack Offline
696pack  Offline
AZ.
Yeah but that is a Satelitte and it would be a 330 h.p.
Re: 440, 4-speed, A/C ? [Re: 696pack] #1268488
07/29/12 02:17 AM
07/29/12 02:17 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
This is the second case I have heard of it. I have never seen one in person but don't doubt there may have been a few built. It likely would have been at the request of a high level factory executive that wanted one for themselves. They got what they wanted even if they would not built one for the public. Certainly all of the components were factory assembly line readily available so it would not be a big deal to do.
If the car has a broadcast sheet that will tell you if it was factory built.
Really Daryl? What if the car in question has one of your bogus home made Broadcast Sheets? Heck anything's possible right?
Re: 440, 4-speed, A/C ? [Re: 696pack] #1268489
07/29/12 02:22 AM
07/29/12 02:22 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Not quite:
all 1970 383 4bbl engines with manual transmissions are "orange/Holley" 383HP (335hp)
all 1970 Challenger R/T, 'Cuda, Charger, Super Bee, Road Runner 383s are "orange/Holley" 383HP (335hp)
NO (ZERO) 1970 c-bodies with 383HP (335hp)
..... but that's another thread
anyone with proof of that factory 440 4-spd MOPAR with A/C, yet?
Re: 440, 4-speed, A/C ? [Re: 6bblgt] #1268490
07/29/12 03:36 AM
07/29/12 03:36 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Not quite:
Thanks Dan. That is why I posted:
Chrysler engineers were pretty smart people. If the Head Office or Sales said they wanted something, I'm pretty sure they could have figured out a way to make it work.
If people take the side "you could get anything you wanted" and believe these cars existed, then the engineering work WAS ALREADY done and the combination could have easily been offered to the general public. Yet...it wasn't.
Just my opinion, but I don't think the 440-4 speed was not offered because of some compressor/cam/gearing issue. If the engineers figured out a way to make it work with a 383, I'm reasonably sure they could do the same for the 440.
Seeking:
Re: 440, 4-speed, A/C ? [Re: 69CoronetRT] #1268491
07/29/12 04:12 AM
07/29/12 04:12 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
The vast majority of 383 4-spd cars with A/C are 3.23 geared.
I've heard but have no proof, which is why I've refrained until now to add it to this fantasy witch hunt for cars Chrysler didn't build. Chrysler didn't want to deal with A/C compressor warranty issues arising from high RPM decel on 440 4-spd vehicles, most with 3.54 gears. Decel having more "violent" RPM changes than accel.
In the '60s 440 4-spd cars were "race cars" for the street not cruisers that most owners wanted W/O power steering, power brakes, or A/C.
Chrysler execs had "company cars" for short periods of time. Wild, exoticly optioned factory assembly line built exec cars do not exist.
Re: 440, 4-speed, A/C ? [Re: 6bblgt] #1268492
07/29/12 03:07 PM
07/29/12 03:07 PM
AZ.
696pack Offline
696pack  Offline
AZ.
Not quite:
all 1970 383 4bbl engines with manual transmissions are "orange/Holley" 383HP (335hp) all 1970 Challenger R/T, 'Cuda, Charger, Super Bee, Road Runner 383s are "orange/Holley" 383HP (335hp)
And how can you PROVE that?
I am looking at GGs white book that shows an E63 sales code for ALL 383-4 regardless of 330 or 3435 h.p. In fact it shows the 330 h.p. for B bodies with A/C for 69-70. You can not tell by the fender tag or V.I.N. if a car was a 330 or a 335 h.p.
Factory exec car could be kept for years and some were. If they wanted something special they got it (within reason) and they didn't care how long they were going to keep the car.
It was the factory cars used by the sales and service reps that got turned over quickly depending on the miles. Some that had a big territory only had a car for 3 months others a full year.
