Griffin muscle car radiator? Anyone using one of these? #1268323
07/15/12 06:27 PM
07/15/12 06:27 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Looking at buying this Griffin radiator. http://www.summitracing.com/parts/GRI-5-571GA-FAX/ Was curious if anyone is using one. Can you use a factory shroud on these? Does it keep your car cool? Also how do the tranny cooler fittings line up with where the factory ones are?
Re: Griffin muscle car radiator? Anyone using one of these? [Re: 70VcodeCoronetRT] #1268324
07/15/12 06:35 PM
07/15/12 06:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had a Griffin "universal" radiator in my racecar since 1994, no issues, works fine; can't speak for the OEM-style, though. $600 seems spendy for the one in the link but it looks nice & probably fairly stock if painted black.
Re: Griffin muscle car radiator? Anyone using one of these? [Re: topside] #1268325
07/15/12 07:19 PM
07/15/12 07:19 PM
Midwest
fuseable Offline
fuseable  Offline
Midwest
I have one in a 64 dodge (2 row 1 1/2 tubes, direct bolt in) 4 years now and no problems. I would do it again.
Re: Griffin muscle car radiator? Anyone using one of these? [Re: 70VcodeCoronetRT] #1268326
07/15/12 07:23 PM
07/15/12 07:23 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have Wizard cooling radiator in my car, with stock shroud and fan. Works great in the hot humid summer.
https://wizardcooling.com/products/171-1970-73-26-bb-mopar-applications.aspx
Re: Griffin muscle car radiator? Anyone using one of these? [Re: 70VcodeCoronetRT] #1268327
07/15/12 07:33 PM
07/15/12 07:33 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
I have a Griffin. The transmission cooler lines were not in the correct location. Griffin could not care less. Their after sales custom service was very poor.
It cools fine
Re: Griffin muscle car radiator? Anyone using one of these? [Re: BSB67] #1268328
07/15/12 08:03 PM
07/15/12 08:03 PM
Nebraska
Nebraska
Any pictures of your Wizard in the car? Thanks
Re: Griffin muscle car radiator? Anyone using one of these? [Re: 70VcodeCoronetRT] #1268329
07/15/12 09:04 PM
07/15/12 09:04 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I installed a 26" one in a buddy's car a few years ago. Dropped right in. Factory shroud bolted on perfect. Looked stock.
But... he ordered the higher horsepower version with the thicker core. Factory fan and clutch wouldn't fit. Had to install a Jaguar fan clutch. With the benefit of hindsight, he should have just ordered the stock replacement one which would have been more than adequate.
Another buddy purchased a 22" unit for his 340 'Cuda, and it did not resemble a stock unit. Had a stamped tank, but lacked the ribbing. On top of that, his car still runs hot, but I think he's got other issues.
I'm potentially in need a of a 22" radiator (my stock one is leaking, but repairable). Not sure I'd want to use one of the Griffins in my stock appearing engine bay.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Griffin muscle car radiator? Anyone using one of these? [Re: 70VcodeCoronetRT] #1268330
07/15/12 09:15 PM
07/15/12 09:15 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I have one. It looks stock after I painted it with eastwoods radiator paint. I bought the paint at Jegs. The factory 326 shroud for my challenger drops right on but I did have to drill the shroud mounting holes. Can't say as to the performance yet as I haven't fired the engine yet.
Re: Griffin muscle car radiator? Anyone using one of these? [Re: HEMIDOG 70] #1268331
07/15/12 09:58 PM
07/15/12 09:58 PM
ILL
Greentween Offline
Greentween  Offline
ILL
I just recieved that same griffin a few weeks ago. I am happy with it. The stamped upper tank resemble a stock type tank and polished up very nice. I had a champion before and the wizard (my second choice) has the same kind of upper tank, which I didnt like. The welds on the wizard are much nicer then the champion though. There is a flange for the shroud to bolt to, you just need to drill the holes in the flange like posted above. I dont have stock trans lines so, no comment about how those would fit as I have braided lines.
Re: Griffin muscle car radiator? Anyone using one of these? [Re: Greentween] #1268332
07/16/12 11:36 AM
07/16/12 11:36 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Griffin's have epoxy, cant repair the take to core joint area. Tim
Re: Griffin muscle car radiator? Anyone using one of these? [Re: 70VcodeCoronetRT] #1268333
07/16/12 12:27 PM
07/16/12 12:27 PM
London,Ontario,Canada
1962Savoy Offline
1962Savoy  Offline
I have a 26" two core and I made my own shroud works really well!
Re: Griffin muscle car radiator? Anyone using one of these? [Re: 1962Savoy] #1268334
07/16/12 02:30 PM
07/16/12 02:30 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..Griffin rads are epoxy dipped after welding..added leak protection.
leaks are easily welded if required.
i have the musclecar rad and itis similar to factory but obviously not correct..i like it
Re: Griffin muscle car radiator? Anyone using one of these? [Re: can.al] #1268335
08/07/12 01:53 PM
08/07/12 01:53 PM
Nebraska
Nebraska
Ok just ordered this one. Can anyone tell me if it comes with any of the fittings? Or do I need to buy those? If so what size do I need to fit the radiator? Will I be able to swap out my trans cooler fittings from the factory radiator? Thanks
Re: Griffin muscle car radiator? Anyone using one of these? [Re: 70VcodeCoronetRT] #1268336
08/07/12 04:26 PM
08/07/12 04:26 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I ordered this Griffin radiator for an E-body.
From my experience. I ordered the radiator, without any of the mounting holes added. I did this so I could place it exactly, where I wanted it to sit. The factory shroud bolted on however, there was a slight gap between shroud and radiator. I added some foam to the shroud side to close this small gap. Not sure what you are going to do for an overflow but you may need to consider this if you haven't yet.
The transmission fittings from my old radiator screwed into the new Griffin. Not sure what size they are but they interchange.
