84 Dodge D250 Stalls on Electrical Demand #1267760
07/14/12 02:11 PM
07/14/12 02:11 PM
Indiana
Dave74 Offline OP
Dave74  Offline OP
Indiana
Put a new alternator, new battery, new fusible link, and can jump start the truck and it runs. As long as it's linked to the jump vehicle, the radio and a/c works.
I let it idle for an hour, then went out and turned on the a/c and the truck stalled out again. Won't start unless I jump it...again.
Guidance?
84 Dodge D250 Ram Prospector, .360 engine, auto, air, etc...
Re: 84 Dodge D250 Stalls on Electrical Demand [Re: Dave74] #1267761
07/14/12 02:37 PM
07/14/12 02:37 PM
Indiana
Dave74 Offline OP
Dave74  Offline OP
Indiana
surely it can't be a bad battery, it was installed on June 1st.... dead cell already?
Re: 84 Dodge D250 Stalls on Electrical Demand [Re: Dave74] #1267762
07/14/12 03:15 PM
07/14/12 03:15 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The battery lead cables could have internal corrosion, limiting their effectiveness. I've had cables that were old but looked okay from the outside, but wouldn't provide adequate power.
Re: 84 Dodge D250 Stalls on Electrical Demand [Re: Dave74] #1267763
07/14/12 03:30 PM
07/14/12 03:30 PM
I'd clean the large batt cables and the brass terminals in the bulkhead. Use a NAPA brass 1/4" male terminal #725147 to clean the female ones in one half of the bulkhead and a small steel bristle brush to clean the male ones in the other half. If needed check/clean the starter relay terminals and it's ground
Re: 84 Dodge D250 Stalls on Electrical Demand [Re: Dave74] #1267764
07/14/12 03:51 PM
07/14/12 03:51 PM
scratchnfotraction Offline
check the triangle rubber plug at the fuseable links,make sure the fuselinks are all good.
I know you replaced some but make sure they did not burn again. how did you splice them in? crimp connectors?
check the alt batt wire on pass side running down vc to the firewall plug. its a spade plug that will burn up.
you should replace the volatge regulator and clean the firewall for a good ground with every alt change.
replace the ballist resistor also,then check to see if the alt is charging.
if its not charging a power draw will kill the Batt in short order and engine will die with more power draw.
Re: 84 Dodge D250 Stalls on Electrical Demand [Re: scratchnfotraction] #1267765
07/14/12 04:07 PM
07/14/12 04:07 PM
ifin it was mine to fix...
I have fixed many like this by striping all the stock crap out and run a points dist with a pertronix points conversion.
by-pass BR for full 12 volts to the coil,unplug the ecu and all the other crap tape the plugs up and tuck it all behind the fender brace so it looks like this.
that will only leave the alt/VR/feild/Batt wires,only thing on the fender is the stater relay.(which i just had to fix the alt batt wire at the firewall plug,it kept blowing headlights and smokeing alts on the 85 truck.)
