Page 5 of 36 1 2 3 4 5 6 7 35 36
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: Golden-Arm] #1267319
08/16/12 09:41 PM
08/16/12 09:41 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
dont forget the "Drips Oil Drops Grease Everywhere" isnt just for fun. if it's not marking it's territory, it's not a dodge!!
Well that's good to know! At least I know my Dart doesn't have an identity crisis. BTW, I just took it out yesterday for a church bbq and afterwards I filled it up with gas. I put 13 gallons in it and it cost me $56.50!
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267320
08/23/12 01:05 PM
08/23/12 01:05 PM
SoCal
SoCal
I've been beading around the bush with this idea, but I think after Fall Fling I am going to officially retire the Dart's cruiser state and just start taking it apart to fix the little things and hot rod it.
My friend with the 71 Demon has already given me some ideas on the Dart on how to fix some of the things that don't look so good. Who knows, maybe we could do a thing where one weekend we work on his car and another we work on mine. Right now he's completely redoing the suspension and is waiting for parts to come in. He is kind of bugged and just wants to drive it again since it has been apart all summer.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267321
08/23/12 02:39 PM
08/23/12 02:39 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
sounds like a great opportunity for both of you to learn more about your cars! also, putting beads around your bush doesn't sound like great mulching to me but you Cali guys have alot of weird stuff out there .
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: mikemee1331] #1267322
08/23/12 06:52 PM
08/23/12 06:52 PM
SoCal
SoCal
My friend already knows a lot and has already restored his Demon once (kinda twice) by himself. He's very knowledgeable and is very good at machining things as well. He got his Demon 4-5 years ago in way worse condition than mine and his looks absolutely amazing for seeing what a guy in his early 20's can do.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267323
08/23/12 07:27 PM
08/23/12 07:27 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
well then it's a win-win for you! keep it up dude, i like watching your progress and growth in the hobby!
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: mikemee1331] #1267324
08/23/12 07:44 PM
08/23/12 07:44 PM
SoCal
SoCal
He's currently redoing his suspension. He had some alignment issues due to his old upper control arms so he got rid of them and put in some tubular RMS upper control arms. He's currently waiting for his stage 3 box from Firm Feel. His torsion bars should be coming in soon after waiting for them for over a month and a half. He's replacing his fuel cell with a stock tank because he decided he likes the cruising aspect more than the full on race car approach. He also found a weird disc brake conversion kit for like $200 that uses some toyota rotor and weird caliper. The instructions for redrilling the bolt pattern were shady though. So he's waiting to put all of those back in.
But so far he has a built up 318 (carb and headers), a shift kit, home made subframe connectors, adjustable shocks, completely redone interior (with procar rally seats), and he did all the body work himself. It's pretty nice for just a college student making an ok paycheck.
Here are pictures from 6 months ago...
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267325
08/23/12 08:12 PM
08/23/12 08:12 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
sweet ride! i said it before - you California guys have it made!
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267326
08/24/12 04:53 AM
08/24/12 04:53 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Don't take it apart! It snowballs then you have a pile of parts! DAMHIK. Try and fix one thing at a time. Sometimes getting in and driving it down the road is needed to refresh your enthusiasm. So please, don't take a bunch of stuff apart at once. Restore it to cruiser status after each upgrade and you will be much happier!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: OhioMopar] #1267327
08/24/12 12:47 PM
08/24/12 12:47 PM
SoCal
SoCal
Well, not completely apart where I've got everything pulled out of the engine bay and all that. In whole it will still be mostly together. I'd like to do a 4 wheel disc brake, bigger wheel, big bolt swap this year so that's what I was talking about when I meant primarily by taking it apart. I was driving it yesterday and the 205/75/14 tires and 2.94 rear gear ratio really dog down the car. But overall, for the most part it should be together.
Interior most likely won't be touched except for the steering column that I'm going to take out and fix (I'm replacing the manual steering shaft for a PS one and I may put in an aftermarket steering wheel). Engine and Trans are going to sit where they are and won't be touched (I am probably going to buy and replace all of the hoses and clean up the engine bay wiring). As far as suspenion goes I'm probably going to replace the shocks and see if my buddy can help me fab up subframe connectors. Paint and body won't be touched. And of course I'm going to work with all the little bugs around the car. I just want to slowly move away from cruiser status.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267328
08/25/12 06:40 PM
08/25/12 06:40 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Slowly is good. Before you embark on an improvement, make sure everything to do it is right in front of you. Don't be waiting on parts. Don't have ALMOST everything, just need to wait on the money to do that one last thng! This happen, then you are missing one part, you broke the stock this taking it off and you are stuck with a really big paperweight you can't drive or enjoy. That's when you start getting discouraged and tired of the project.
I'm just trying to help keep you from making the same mistakes I did.
I had a '69 Bee once. If was from Texas, but Texas isn't always without rust. Anyway, it ran, it drove(kind of) and it was complete. Needed tires, carb, alignment(if that didn't help a little, front suspension) a different gear, and eventually a lot of body work. Instead of working on the this I could fix and stick enjoy it, I tore it down to nothing and then spent the next 3-5 years trying to sell it because I didn't have the money or time to put it back together! A set of tires and a carb and I would have been driving a really ugly b5 blue 4spd Super Bee with a '69 hp 440 in it!
That's my experience. Hope you see what I'm getting at and how quickly something can spiral out of reasonable control!
Good luck, again, on your sweet ride!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: OhioMopar] #1267329
08/25/12 07:50 PM
08/25/12 07:50 PM
SoCal
SoCal
I understand. My friend with the Demon right now is acting the same way. He is kind of discouraged waiting for all of his suspension components to come in the mail. Honestly, right now I haven't touched or done anything to the Dart since I changed the PS hose. I just drive it once or twice a week for fun.
I have an upper radiator hose, fuel filter, and by pass hose I bought sitting in the trunk because I am still waiting to buy the lower radiator and heater hose with some new clamps. Just so I can get them all done at the same time. I'm also kind of waiting to get some proper tools. I'm probably going to order some line wrenches this weekend and buy a proper jack with stands at Costco next month.
I won't start the big bolt swap till I have every component when it comes to brakes, spindles, rear end, drive shaft, wheels, and tires. And the little bugs (windows and locks) I can work with the car whether it is running or not.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267330
08/25/12 08:58 PM
08/25/12 08:58 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Know I understand. My friend with the Demon right now is acting the same way. He is kind of discouraged weighting for all of his suspension components to come in the mail. Honestly, right now I haven't touched or done anything to the Dart since I changed the PS hose. I just drive it once or twice a week for fun.
Happy wrenching!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: OhioMopar] #1267331
08/25/12 09:07 PM
08/25/12 09:07 PM
SoCal
SoCal
Holy crap I just realized how many terrible spelling errors I had in my last post. They will be fixed!
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267332
08/25/12 10:57 PM
08/25/12 10:57 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Time to start on some mall projects.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: moparpollack] #1267333
08/25/12 11:06 PM
08/25/12 11:06 PM
SoCal
SoCal
Mall projects???
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267334
08/26/12 09:50 AM
08/26/12 09:50 AM
85086
Lil Herman
Lil Herman
85086
Yes the mall projects where you can roll down your windows to when you o to the mall.
That or I am bad at typing.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: moparpollack] #1267335
08/26/12 01:12 PM
08/26/12 01:12 PM
SoCal
SoCal
I've never heard of that before.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #1267336
09/02/12 04:13 AM
09/02/12 04:13 AM
SoCal
SoCal
Just drove the car 55 miles today and she drove smooth. On my way home my average speed was about 70-75 mph and it ran great! Tomorrow my mother is getting married and I should be driving it another 50 miles or so. Maybe I'll get some more shots of the car.
Only bad thing about today is the driver's windshield fell off the regulator AGAIN!!! It was just a little cold on my way home. I really don't want to pull off the door skin again and screw it up more than I already have. My friend is going to lend me the proper tools to do so instead of me prying them off with my hands.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: OhioMopar] #1267337
09/02/12 04:49 AM
09/02/12 04:49 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I made that mistake too. My first car was non running to start with, a mistake.
Don't start taking your first running project car all apart making it a non running.
Taking the car all apart isn't going to fix the leaks or drivers window.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: autoxcuda] #1267338
09/02/12 01:58 PM
09/02/12 01:58 PM
SoCal
SoCal
Yeah, my buddy with the Demon saw the car yesterday and was saying, "Wow, I wish I started off with something this nice." He really liked the interior and flipped out when he saw the lower dash pad because he's never seen that before.
