Order of operations Dart front clip
#1267164
07/13/12 10:24 PM
07/13/12 10:24 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Was about to bolt the radiator in tonight and started thinking. I probably need to get the fenders, grill, headlight buckets, etc. mounted before I do the radiator (without having to pull it later). The grille/hood latch support frame has adjustment and the lower bolts are captured by the radiator. So seems like I should get everything bolted together and adjusted first. This make sense?
383, Hemi 4-Speed, AlterKtion, D60
Re: Order of operations Dart front clip
[Re: Jim_Lusk]
#1267166
07/14/12 08:21 AM
07/14/12 08:21 AM
Crazy68Dart
Canton, Ohio
Thanks Jim.
I need to get the hinges and springs installed before I do anything.
