can a cast iron hemi head flow 400 @600 lift with porti #1266571
07/12/12 07:50 PM
07/12/12 07:50 PM
Maryville TN
68528hemi Offline OP
Maryville TN
will a newer cast iron hemi head flow 400@.600 lift. I know it would take some porting.Just want to know if it can be done on cast iron.I know it is no problem on stage 5 and newer m.p heads. thanks
Re: can a cast iron hemi head flow 400 @600 lift with porti [Re: 68528hemi] #1266572
07/12/12 09:52 PM
07/12/12 09:52 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yes.
Re: can a cast iron hemi head flow 400 @600 lift with porti [Re: Dragula] #1266573
07/12/12 11:25 PM
07/12/12 11:25 PM
Maryville TN
Maryville TN
how much do you think it would cost to get ther
Re: can a cast iron hemi head flow 400 @600 lift with porti [Re: 68528hemi] #1266574
07/13/12 06:07 PM
07/13/12 06:07 PM
dogdays Offline
dogdays  Offline
I'm thinking it was Dan Dvorak who tested a stock iron Hemi head and got 315 cfm at probably 0.700 lift, so IMHO it's doable.
You need to move this question into the Race section.
R.
Re: can a cast iron hemi head flow 400 @600 lift with porti [Re: 68528hemi] #1266575
07/13/12 07:29 PM
07/13/12 07:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
will a newer cast iron hemi head flow [Email]400@.600[/Email] lift. I know it would take some porting.Just want to know if it can be done on cast iron.I know it is no problem on stage 5 and newer m.p heads. thanks
They should, I have a pair off a 2005 crate hemi that are about 375cfm with some porting done by member fast68plymouth ... Dwayne Porter ....
If I am remembering what he told me correctly ...
Depends on who does the work and what they flow now ...
If your heads are the new iron heads from ebrock they flow better than the heads off my 2005 crate motor to begin with.
Re: can a cast iron hemi head flow 400 @600 lift with porti [Re: JohnRR] #1266576
07/14/12 01:42 AM
07/14/12 01:42 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Floyd Lippencott IV
Re: can a cast iron hemi head flow 400 @600 lift with porti [Re: mr_340] #1266577
07/14/12 01:46 AM
07/14/12 01:46 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
This is on an aluminum MP head, but I think Jeff runs the same program on the cast iron version. This is a ten year old program, and I think his newer one flows better than this.
Floyd Lippencott IV
Re: can a cast iron hemi head flow 400 @600 lift with porti [Re: mr_340] #1266578
07/14/12 02:07 AM
07/14/12 02:07 AM
Maryville TN
Maryville TN
I spoke to jeff today and just like you said about the flow. So my heads are on the way to him. Seams to be a cool guy.
