Re: File fitting Rings..end gap?
[Re: hemi4speed]
#1264882
07/09/12 08:49 PM
07/09/12 08:49 PM
Posts: 3,396 Pa
Hot 340
Pa
[Re: hemi4speed]
#1264885
07/10/12 09:34 AM
07/10/12 09:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I believe the spec is .004 per inch of bore... I like to make the second ring .004 larger than the top so it doesnt hold any pressure
[Re: hemi4speed]
#1264886
07/10/12 01:45 PM
07/10/12 01:45 PM
Thumperdart
State of confusion
On my 4.377 bore big block I set the top at .018 and my second at .027 per Pettis`s recommendation.............he`s fnding that the larger than normal second ring gaps work very well in most applications.
[Re: mickm]
#1264888
07/10/12 09:27 PM
07/10/12 09:27 PM
Posts: 1,532 off the grid
340B5
off the grid
I did mine at .022, .024 per Wiseco recomendations. The gap isn't as important as making sure the second ring is a couple thousands wider gap. The wider gap on the 2nd ring helps prevent ring flutter.
Yeah, it's got a smallblock.
