Re: New gas tank installment problems can you help?
[Re: mopardiebold]
#1264402
07/08/12 10:45 PM
07/08/12 10:45 PM
RapidRobert
Sometimes a worn pump will not prime at slow cranking speeds. Fill the carb bowls thru the bowl vents so it will run for 10 seconds or so & see if it will pump. If no go check the 2 neoprene lines on the hard lines and pull the pump & check the pushrod, no scalloped ends & the length when new is 3&1/4"
[Re: mopardiebold]
#1264404
07/09/12 12:03 AM
07/09/12 12:03 AM
moparpollack
Lil Herman
Lil Herman
85086
Take the fuel line loose at the pump, jack the car up on the drivers side to where the front line is lower than the fuel tank. Fuel should gush out of the line if it is not blocked. The line should be primed for the pump to pull fuel up to he carb. If it don't pump from here get ready to change a pump.
[Re: moparpollack]
#1264405
07/09/12 12:57 AM
07/09/12 12:57 AM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
Make sure its a NEW filter. Second - try another new pump. New tank, new sending unit and new lines = no restrictions. Therefore its down to the first two mentioned. Let us know when you figure it out!
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
[Re: mopardiebold]
#1264407
07/09/12 08:15 AM
07/09/12 08:15 AM
Challenger 1
Cincinnati, Ohio
Either you have leak on the suction side, or a short push rod if this is a BB. If sb maybe you have the fuel pump installed wrong? Just Saturday I installed a gas tank with new lines on a sb challenger. I only had to crank it for less than minute to get gas to the carb and for it to start after I poured 5 gallons in the tank. Also I hope you don't have a filter in front of your fuel pump, because it can't suck through a filter that is designed to go after the pump. Only the sock in the fuel tank should be between your pump and fuel tank.
[Re: mopars4ever]
#1264413
07/11/12 02:02 AM
07/11/12 02:02 AM
Posts: 370 sandusky ohio
mopardiebold
sandusky ohio
This maybe a dumb question but any way I have the carb full of gas and it still won't start I have the alternator off does the alternator need to be on and the wires pluged in for it to fire I don't think so but thought I'd ask the car does have the msd box. Thanks again paul
