70 Charger 500 Tail Panel numbers ; Updated
#1264182
07/08/12 03:03 PM
07/08/12 03:03 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Restoring the tail panel on my 70 Charger 500 and the original holes were filled in poorly by previous owner and "500" replaced with the standard Charger script with medallion emblem.
I've stripped it down and located the holes;
Question is, the "Charger" and "500" appears to be separate? If separate, where can I get a "500" badge? Or both?
The "500" on the grill IS larger than what would be on the rear.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 70 Charger 500 Tail Panel numbers ; Updated
[Re: Hoof Hearted]
#1264183
07/08/12 11:05 PM
07/08/12 11:05 PM
Hoof Hearted
S.E. Conn
Stripped entire panel with a 24 hour soak in Brake Fluid;
Any recommendations on what detergent/cleaner to use to rid of any residual brake fluid or contaminants before priming and painting?
[Re: Mr.Yuck]
#1264185
07/13/12 12:47 PM
07/13/12 12:47 PM
Hoof Hearted
S.E. Conn
Here's some updates for anyone interested in future 70 charger restos
[Re: Hoof Hearted]
#1264186
07/13/12 12:49 PM
07/13/12 12:49 PM
Hoof Hearted
S.E. Conn
Used the existing Left 2 mounting hole for "Charger" script and had to modify slightly the Right 2 mounting holes to mount the Repo ($30 on Ebay) "500" script.
Also, note the Emblems aren't quite centered; Could this have been an R/T tail panel?
On second pic (installed with no tail light gaskets yet) you can see the light housing is off a bit, i'll be widening out mounting the holes on final install.
[Re: DAYCLONA]
#1264188
07/24/12 01:57 PM
07/24/12 01:57 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I stripped mine with Brake clean on my R/T 22 years ago & repainted it. Still looks good. My other 70 is a 500 S.E. & has this same tail panel.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1264189
07/24/12 01:58 PM
07/24/12 01:58 PM
6PKRTSE
Motor City
Appears to be seperate. Here is a picture of my other 70 500 S.E. panel. Car is all original & in rough condition.
[Re: 6PKRTSE]
#1264190
07/24/12 02:02 PM
07/24/12 02:02 PM
6PKRTSE
Motor City
Picture of my other 70 500 S.E. as it sits in storage.
