spark plug gap? #1263488
07/07/12 02:36 PM
07/07/12 02:36 PM
california santa clarita
moparpete22 Offline OP
putting some new spark plugs in my 340 cuda with the electronic ignition (orange box)and was wondering which gap i should use?
thanks for your help
Re: spark plug gap? [Re: moparpete22] #1263489
07/07/12 02:46 PM
07/07/12 02:46 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
I have the same electronic box and my plugs are gapped at .035.
Re: spark plug gap? [Re: moparjo68] #1263490
07/07/12 04:24 PM
07/07/12 04:24 PM
As Joe said .035" will work excellent. You could experiment with .030" and .040" & see how it acts. FYI NAPA sells a Mopar rotor, (Echlin MO-3000 iirc) with a .060" longer blade will will help with spark scatter/rotor phasing issues if needed and I'd rather have the spark energy all being used inside the combustion chamber rather than being dissipated jumping a large gap from the rotor blade to the cap terminal
Re: spark plug gap? [Re: RapidRobert] #1263491
07/07/12 04:44 PM
07/07/12 04:44 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that's interesting! how did you stumble on that RR?
Re: spark plug gap? [Re: mikemee1331] #1263492
07/07/12 04:52 PM
07/07/12 04:52 PM
Someone (on here) iirc way back provided the Echlin # and Jacobs ignition ("Aunt Tillys tips" in their bible) has some interesting info on how different gaps will affect how it starts/runs/maintenence intervals/power produced
Re: spark plug gap? [Re: moparpete22] #1263493
07/07/12 06:00 PM
07/07/12 06:00 PM
Great. thank you very much.
I'll look into that at NAPA
