Re: schwartz performance What do you think? [Re: Supercuda] #1263279
07/23/12 03:07 PM
07/23/12 03:07 PM
Dale@Schwartz Offline
"Your Mopar’s uni-body construction is inherently weak. Our G-Machine Chassis isn’t."
A ladder frame is strong?
LOf'iingL
Looks like a great way to p!ss away lots of money.
Cracker Jack U strikes again.
Hello all,
it seems there is some confusion on our chassis system. We convert them to a full frame instead of using subframe connectors, because it's stronger. Keep in mind that our chassis works TOGETHER with the unibody construction, it doesn't replace it. The suspension, engine, and drivetrain will now bolt to a frame instead of spot-welded pieces of sheet metal.
The welded frame itself is under $5k. We use mandrel-bent frame rails.
If you look at the parts that are included, you'll see that our standard brake kit is 13", you get a power rack, single-adjustable coilovers, a truetrac diff / 31 spline axles, and a full-floating Moser 9" housing.
Yes, its much cheaper for you to get small 11" brakes and non-adjustable coilovers, and to keep your stock rear end.
We've won or placed well against our competitors with our chassis systems. Just this weekend our customer's 1984 Monte Carlo placed 3rd in the Car Craft Magazine Real Street Eliminator autocross competition, yes... even against new SRT8 Challengers! Driving skill? It was our customer's 2nd autocross event ever.
Anywho, if you have any other questions please feel free to email us, or call at (815) 206 2230.
Have a nice week!
Re: schwartz performance What do you think? [Re: Dale@Schwartz] #1263280
07/23/12 04:23 PM
07/23/12 04:23 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If I ever get an E body or 68 Charger I will do it up with the works like one of your setups. It is something that needs done from the get go IMO. Even if you offered an A body model I wouldnt convert my current car because its just more than I want to do on a car that is already cosmetically done.
Mopar to the bone!!!
Re: schwartz performance What do you think? [Re: hulmule] #1263281
08/17/12 11:34 AM
08/17/12 11:34 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
A little re-hash...
From their site: "Your Mopar’s uni-body construction is inherently weak. Our G-Machine Chassis isn’t.
The sheet-metal that your suspension components and engine are mounted to begins to flex dramatically once you add more horsepower, higher spring-rates and better brakes."
What a crock.
Compare any perimeter-frame car of the '60s to any Mopar of the same era. Drive a corner of that GTO up on a curb...you can't even open the door! And the Mopar was lighter, etc. The only downside: Noisier and a bit more ride harshness.
Look at all the modern stiff / handling cars: ALL are unibody with rail-thru construction (BMW - Mercedes, etc.) all pirated from B-vans and Jeep Cherokee designs!
I have no doubt that adding a perimeter frame to the unibody will create a very stiff platform -- the factory has done that (Imperial). But, what's the weight penalty? You can get the same effect with frame connex, torque boxes, and the XV braces, which, in total, add maybe 30-35 lbs.
Rick
Re: schwartz performance What do you think? [Re: Rick_Ehrenberg] #1263282
08/17/12 12:29 PM
08/17/12 12:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not to mention thousands of dollars less, even if you farm the work out.
Don't be the exception.
Re: schwartz performance What do you think? [Re: Supercuda] #1263283
08/18/12 05:28 PM
08/18/12 05:28 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Any reply from Mr Schwartz himself?
Re: schwartz performance What do you think? [Re: 67autocross] #1263284
08/18/12 07:10 PM
08/18/12 07:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I just had to...
Re: schwartz performance What do you think? [Re: 1_WILD_RT] #1263285
08/18/12 07:44 PM
08/18/12 07:44 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
