What causes carbon in intake runners and carb? #1263229
07/06/12 09:26 PM
07/06/12 09:26 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
I'm assuming it is carbon, but it might not be. What causes the black (carbon?) in intake runners and in a carb?
Ran a 750 Holley vacuum secondary carb maybe 10 to 20 hours last year on my daughter's 67 coronet with a 383. Was freshly rebuilt when I installed it. The carb is now heavy black.
My cousin's 400 cid 67 Firebird with a Paxton supercharger has half the runners black and half clean. Its a dual plane that we now know is a mistake. The cylinders that are rich have the black runners.
What is causing this?
Re: What causes carbon in intake runners and carb? [Re: markz528] #1263230
07/06/12 10:08 PM
07/06/12 10:08 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
Reversion. Wrong cam, carb, intake, heads, pistons, etc, etc, etc... Whatever combination you have isn't matched very well and isn't working to it's best capabilities. It may run great, (in your mind), but sounds like it has a very long ways to go to be tuned to it's fullest potential. Good luck
Re: What causes carbon in intake runners and carb? [Re: stevet340] #1263231
07/06/12 11:16 PM
07/06/12 11:16 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
does it have a working pcv valve?
Re: What causes carbon in intake runners and carb? [Re: stevet340] #1263232
07/06/12 11:50 PM
07/06/12 11:50 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Reversion.
+1
rebreathing, bringing internal residuals into the intake, due to the timing of valve events, could be something else, but that is when I normally see it.
Good luck
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: What causes carbon in intake runners and carb? [Re: OUTLAWD] #1263233
07/07/12 12:22 AM
07/07/12 12:22 AM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
[/Reversion. Wrong cam, carb, intake, heads, pistons, etc, etc, etc... Whatever combination you have isn't matched very well and isn't working to it's best capabilities. It may run great, (in your mind), but sounds like it has a very long ways to go to be tuned to it's fullest potential. Good luck quote] :
Too much overlap
Re: What causes carbon in intake runners and carb? [Re: mopartoby] #1263234
07/07/12 12:25 AM
07/07/12 12:25 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
are you running pump gas?
Re: What causes carbon in intake runners and carb? [Re: a493demon] #1263235
07/07/12 12:51 AM
07/07/12 12:51 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
What's the ignition timing? Initial, total?
Camshaft?
Re: What causes carbon in intake runners and carb? [Re: RobX4406] #1263236
07/07/12 03:41 AM
07/07/12 03:41 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
it is overlap-
look at newer engines with no EGR, they run a TON of overlap- particularly the new VW diesel's are horrible with this. after 50,000 they look like a million miles on them. they run this much overlap to reduce emissions... but we use it too... just not for emissions
Re: What causes carbon in intake runners and carb? [Re: 8urvette] #1263237
07/07/12 03:43 AM
07/07/12 03:43 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
when i used to do import turbo engines that were DOHC we would retard one cam and advance one cam to reduce overlap to help build boost faster... more exhaust going out the exhaust, not back into the intake.
Re: What causes carbon in intake runners and carb? [Re: 8urvette] #1263238
07/07/12 11:22 PM
07/07/12 11:22 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
To answer some of the questions, the Coronet did have a working PVC and the breather fed into the air cleaner. Both engines run on pump gas.
The 383 internal condition is not known, but given all the leaks and other mechanical work on the car, it probably stinks. The car now has a fresh 440 in it. Have not done any tuning to it yet. Timing is 14/35 - both engines.
As far as my cousin's Pontiac 400, I do buy reversion, but why only on 4 cylinders? What does the blower have to do with it? We do know that we did have too much retard in it. It was probably high teens at full boost.
Re: What causes carbon in intake runners and carb? [Re: markz528] #1263239
07/08/12 12:11 AM
07/08/12 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The Pontiac just has the wrong cam in it... any pressurized
engine doesnt like over lap on the cam... as to your
other car what did you put in for a cam and did you
degree it... did you do a valve job on it
Re: What causes carbon in intake runners and carb? [Re: markz528] #1263240
07/08/12 07:16 AM
07/08/12 07:16 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Low compression and low convertor.
Re: What causes carbon in intake runners and carb? [Re: RemCharger] #1263241
07/08/12 11:07 AM
07/08/12 11:07 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
lot's overlap and restriction on the exhaust in the engines power band can cause this. If that is the case it is not good.........
But if you have lots of overlap, you might just be seeing the signs of reversion at idle.......... No big deal......
Re: What causes carbon in intake runners and carb? [Re: 10.90 Racer] #1263242
07/08/12 11:24 AM
07/08/12 11:24 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Camshaft design (valve event timing),valve jobs,and header efficiency all can affect it.
You can have a ton of overlap and never see signs of reversion if everything else is right.
I am finishing up testing 12 different camshafts in one of my engines,one of them had signs of reversion in the intake runners.
It was the one with the least overlap of all the cams tested.
It has a lot to do with the rest of the valve timing.
Keith
Re: What causes carbon in intake runners and carb? [Re: Dunnuck Racing] #1263243
07/08/12 11:35 AM
07/08/12 11:35 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
My 9.24:1 compression 349" engine had 100.5º of overlap @ .020"
Intake runners and manifold were clean as a whistle.
(Combination, combination, combination!)
Re: What causes carbon in intake runners and carb? [Re: S/ST 3040] #1263244
07/08/12 11:54 AM
07/08/12 11:54 AM
Northern Indiana
Northern Indiana
Vic,
I think a lot of it has to do with the valve job/port design you do.
Flowing good the right direction without flowing good the wrong direction. But then that is probably easier said than done?
Even with 104 degrees of overlap @.020 and too small of a header,no signs of reversion on the 421.
It took too small of a camshaft with very little overlap(too wide of a lsa) and late exhaust timing to show any signs of reversion.
Keith
Re: What causes carbon in intake runners and carb? [Re: S/ST 3040] #1263245
07/08/12 03:23 PM
07/08/12 03:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed...........I`ve got 97 degs. of overlap and my carb and runners are clean..............
