Re: 1967 Steel Wheel 14x5.5 ?
[Re: Beebuzzn]
#1263045
07/06/12 03:04 PM
07/06/12 03:04 PM
Posts: 457 PNW
Beebuzzn
PNW
Picture of wheel. Also 67' style large dog dish fits wheel.
[Re: Beebuzzn]
#1263046
07/07/12 02:05 AM
07/07/12 02:05 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Those look to be correct 67 "Hemi" wheels (all HP 440 and Hemi B-body cars came with those unless ordered with Chrome Road Wheels, all 67 B-body wagons also had them regardless of engine). Later 67 versions had date codes on them (they started adding date codes sometime around March 67). 1966 versions were identical but had an extra hole in between each lug hole. ![](/ubbthreads/images/graemlins/Twocents.gif) *Do you have all 5? Stop the presses! I just noticed the small wheel cover retention nubs on the outer rim areas. Those are not B-body rims, they are the (WAY more common) C-body style.
[Re: NANKET]
#1263056
07/08/12 10:16 PM
07/08/12 10:16 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Does a 440 GTX have the same wheel as a hemi R/T, and the same wheel as a 67 B-body wagon? confused.
Yes, 67 440/Hemi R/T and GTX, and all 67 (B-body) Wagons used the same 14 x 5.5 wheels.
The only versions they used were the style shown in my example (black wheels) above.
The only possible exception would be the 1966 high performance/wagon B-body versions that could have made it on to a few early build 67s. The 66 wheels look identical to the 67s other than having additional holes between the lug holes.
Any other variations that turn up were used on some other application (C-body, truck, later year application, or other brand like Ford, whatever).
[Re: NANKET]
#1263064
07/10/12 10:24 PM
07/10/12 10:24 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
NANKET, I have two sets of wheels, one from a 67 Belvedere I wagon, another from a 67 Hemi GTX. None of them have the nubs as in your photos. I had not previously seen any examples with the nubs on any 67 B-body so your pics got me curious and I did some further digging. I contacted a friend with several original cars, he claims that some have the nubs, and some don't, he's going to get me some pics that I can post so we can hopefully get to the bottom of this. I can only assume that there were multiple vendors or variables between plants. All of my originals have been either St.Louis, or Los Angeles plant cars and none of mine are KH wheels (which is why I asked several times on this thread about the vendor markings). Also, the early examples I have (November 1966 SPD, St. Louis) have no date codes, the later set I have (April 1967 SPD Los Angeles) have date code stampings. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: ScottSmith_Harms]
#1263065
07/11/12 03:00 AM
07/11/12 03:00 AM
Posts: 4,952 northwest USA
NANKET
northwest USA
can you post pics of the centers showing the flats between the lug holes in good detail? Do they have date code or manufacturer stampings (such as "KH"?
Nothing like that, just the 5.5 on the one flat area. Will need to dismount tires and see the bead area.
