Re: 1967 Steel Wheel 14x5.5 ?
[Re: Beebuzzn]
#1263045
07/06/12 03:04 PM
07/06/12 03:04 PM
Posts: 457 PNW
Beebuzzn
PNW
Picture of wheel. Also 67' style large dog dish fits wheel.
[Re: Beebuzzn]
#1263046
07/07/12 02:05 AM
07/07/12 02:05 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Those look to be correct 67 "Hemi" wheels (all HP 440 and Hemi B-body cars came with those unless ordered with Chrome Road Wheels, all 67 B-body wagons also had them regardless of engine). Later 67 versions had date codes on them (they started adding date codes sometime around March 67). 1966 versions were identical but had an extra hole in between each lug hole. ![](/ubbthreads/images/graemlins/Twocents.gif) *Do you have all 5? Stop the presses! I just noticed the small wheel cover retention nubs on the outer rim areas. Those are not B-body rims, they are the (WAY more common) C-body style.
[Re: NANKET]
#1263056
07/08/12 10:16 PM
07/08/12 10:16 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Does a 440 GTX have the same wheel as a hemi R/T, and the same wheel as a 67 B-body wagon? confused.
Yes, 67 440/Hemi R/T and GTX, and all 67 (B-body) Wagons used the same 14 x 5.5 wheels.
The only versions they used were the style shown in my example (black wheels) above.
The only possible exception would be the 1966 high performance/wagon B-body versions that could have made it on to a few early build 67s. The 66 wheels look identical to the 67s other than having additional holes between the lug holes.
Any other variations that turn up were used on some other application (C-body, truck, later year application, or other brand like Ford, whatever).
