Re: Short lived starter relays
[Re: Challenger 1]
#1262863
07/06/12 08:44 AM
07/06/12 08:44 AM
Posts: 5,337 the house on the left.
cogen80
I doubt that all the relays were bad, did you check the plug under the steering coluum and the firewall plug? Also you sure the nuetral safety switch is not giving you trouble? Mine sometimes I have to wiggle my shifter to get it right so the car will start.
you have an issue in the car somewhere, i highly doubt that you got 6 bad relays.
[Re: cogen80]
#1262865
07/06/12 12:51 PM
07/06/12 12:51 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Hold the key in the start position while moving the shifter around, you may need to shifter to neutral or even drive to get the starter to crank.... Keep your foot on the brake...
[Re: AnRT4Me]
#1262866
07/06/12 01:18 PM
07/06/12 01:18 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Just getting ready to post a thread when i saw this
Same issue on my 71 Superbee. Actually this has been an issue for many years. But this last time really has me stumped.
Starter actually engaged while driving the car. Yes you read that correctly ! So i popped the hood after i shut off the motor , the engine still cranking over so i disconnected the battery . Tapped on the starter relay and hooked up the battery again. Started the car then i removed both the ground wire and yellow ignition wire from the starter relay and proceeded down the road . The damn starter relay engaged the starter again while driving . Got it back home and put in another Standard Brand relay and has been fine ever since - I go through these about once a year just driving in summer - Decided to rip one apart the other day - All that is happening inside is the contact points are basically welding themselves together burning out the contacts inside - I have had these fail to the point of no start , and on occasion when starting the car the starter still stays engaged after releasing the key from the start postion - Go tap on the starter relay , everything is fine
All wiring new Newer Ignition Switch a few years back Neutral Safety Switch is new along with wiring Looked over bulkhead connector and cleaned , nothing looked bad Starter new
Honestly I think its just these cheap Standard Brand Relays or what else would cause such a high resistance burning out these contact points inside the relays ???
BWD is an offbrand of Standard correct ???
How about Napa ???
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Challenger 1]
#1262868
07/07/12 07:32 AM
07/07/12 07:32 AM
Posts: 277 Palmyra, NY
63stabamatic
Palmyra, NY
Stater relays are getting cheaper but it's possible your starter is faulty and drawing too much current. You can measure the current with a clip on current meter and compare it to the specs for that starter, (most are 80-90 Amps,free running, in the 69 service manual), or take it to a starter shop who can check it out.
