Page 12 of 16 1 2 10 11 12 13 14 15 16
Re: Hemi vs Wedge [Re: HPMike] #1262738
08/03/12 08:25 AM
08/03/12 08:25 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
That would be Lane Carey's Stang you are talking about. Last I heard it was a 557 wedge eng based on the 429 CJ I believe. Very nice looking and running 71 Stang. Dave's eng was like 496 cubes I think ? Isn't Dave going to run Pure Stock with his new Hemi Super Bee ? Ron
Ron, Both Dudeks' and Carey motors are well into 500 inches. Dudeks is around 528", while Careys' is 588".
Dave D's motor is under 500 cubes. 496..
If Dudek's engine is 496ci and the Mustang is a 588ci BES deal, with what is probaby 15+ compression and a camshaft of epic proportions, including ALL the BES know-how throughout the rest of the assembly and he only has a tenth or so on the Roadrunner (and needs !!!AFTERMARKET !!! steering help to keep the car safe), maybe it's time to look into a max effort BOSS 429......just in case someone builds a HEMI with some current SS technology.
Re: Hemi vs Wedge [Re: jim sciortino] #1262739
08/03/12 09:09 AM
08/03/12 09:09 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
You got it, Jim..
Supposedly the Barton built FAST Hemi put enough power on the dyno that everyone is going to get ...Its a super high revving deal, too..Knowing what I know of Dave D's Hemi build it's surprisingly "low" tech. Credit to the Hemi's inherent design. He's even got a 440Source crank spinning in there
MB
Re: Hemi vs Wedge [Re: HPMike] #1262740
08/03/12 09:33 AM
08/03/12 09:33 AM
Trumbull,CT.
Trumbull,CT.
You got it, Jim..
MB
That's what I hear, Mike......the Barton deal should be stout once it's dialed in.
Maybe BES can slip some "aftermarket" cylinder heads up there and spray paint em' "stock", to go with the "aftermarket" steering components that keep the ford from ending up on it's roof.
By the way, does anyone know the weight of these two cars??? I'd hate to think the ford is the same weight, or lighter and the ever-so-slight ET advantage rests in a few pounds when an almost SIX HUNDRED INCH BES powerplant resides between the framrails.
Re: Hemi vs Wedge [Re: HPMike] #1262741
08/03/12 11:50 AM
08/03/12 11:50 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
You got it, Jim..
MB
Well, Mike the last 'bout that Dudek and Laney had, Dudeks motor was listed at about 528" HEMI. Laneys' motor CR is 14.7 to 1, 588" Ford BB. Dudek was in the 10.20's and BELOW with the 496 incher (and since the video shootout, he's in the nines). As far as a "new" motor for Dudek, I dunno about that at this time. And it isn't much for BES to build a FORD 588", just careful and SMART machining and attention to detail work. Laney did the final assembly. BES has built bigger motors than 588". Regardless, of who has the bigger or better motor, these two friends/rivals DO put on a GREAT showing!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Hemi vs Wedge [Re: HYPER8oSoNic] #1262742
08/03/12 01:19 PM
08/03/12 01:19 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
You got it, Jim..
MB
Daves motor is (was) 497. You will not see that car compete in fast again. A friend of mine bought the car and it has been detuned so he could drive and race it in dragweek. Daves new car will be at the mopar nats next weekend racing in purestock. As for the mustang I had heard that it was like 619cu.in.
JAKES AUTOMOTIVE
Re: Hemi vs Wedge [Re: jim sciortino] #1262743
08/03/12 10:31 PM
08/03/12 10:31 PM
Desert Tracker
Desert Tracker
I've never been to a F.A.S.T. race, but people who have, have told me there are also non-stock suspension parts visible that help with a certain ford front end issue.
You are right.
The aformentioned suspension parts (for the FORD)were allowed by F.A.S.T rules to correct an alignment issue with the stock manual steering setup.
Re: Hemi vs Wedge [Re: HYPER8oSoNic] #1262744
08/03/12 10:59 PM
08/03/12 10:59 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Actually they did that to correct bump steer . Personally I dont think that should been allowed because they could have corrected that without putting that kit on. We had to watch that and make corrections when we aligned Daves car. They also had an issue with the ram air air cleaner that wasnt stock. Dave brought it to their attention that it may not be in the spirit of the class!!!!! Also it was not allowed by the rules because the rules state stock suspension but issue just wasnt pushed at the time.
JAKES AUTOMOTIVE
Re: Hemi vs Wedge [Re: JAKE68] #1262745
08/04/12 01:06 AM
08/04/12 01:06 AM
Desert Tracker
Desert Tracker
Probably a smart move to "overlook" the rule, in favor of safety issues (control), possibly? May not be in the spirit of the class, but better to be SAFE than sorry! Well, if the Ram Air air cleaner wasn't for that particular car, I agree, don't allow it.
Re: Hemi vs Wedge [Re: JAKE68] #1262746
08/04/12 07:38 AM
08/04/12 07:38 AM
Trumbull,CT.
Trumbull,CT.
Sounds to me like that big ole' Roadrunner with that undersized HEMI, is the quickest "legit" car.
Re: Hemi vs Wedge [Re: jim sciortino] #1262747
08/04/12 11:10 AM
08/04/12 11:10 AM
Desert Tracker
Desert Tracker
Dudeks' combo is a PROVEN setup since the "first"
Street HEMI came off the assembly line. One of the MOST popular Mopar platforms to build a GREAT street/strip ride or all out race car. Did a GREAT job of strengthing the weaknessess and enhancing it's strengths. Wonder how much FASTER it would have ran with a "Big Inch" wedge motor!!
Re: Hemi vs Wedge [Re: HYPER8oSoNic] #1262748
08/04/12 01:45 PM
08/04/12 01:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ed Cooks sweet black 63 Maxie ran 10.30's in FAST last year and he said he is sure he will get in the 20's this year. Its great to see wedge in FAST only a few tenths behind the Hemi. And of course you all know I have a soft spot for 63 Max Wedge cars. Ron
Re: Hemi vs Wedge [Re: 383man] #1262749
08/04/12 04:54 PM
08/04/12 04:54 PM
Desert Tracker
Desert Tracker
Re: Hemi vs Wedge [Re: HYPER8oSoNic] #1262750
08/04/12 10:03 PM
08/04/12 10:03 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
At least 3 tenths slower...See Ron's post...
MB
Re: Hemi vs Wedge [Re: HPMike] #1262751
08/05/12 08:59 PM
08/05/12 08:59 PM
Desert Tracker
Desert Tracker
MB
If the Big Wedge was 3 tenths FASTER than the HEMI, Mike, you know that you would be and "unfair"!!! Secondly, YOU'D be about the "cubes"!!
Re: Hemi vs Wedge *DELETED* [Re: HPMike] #1262752
08/05/12 09:11 PM
08/05/12 09:11 PM
Desert Tracker
Desert Tracker
Post deleted by HYPER8oSoNic
Re: Hemi vs Wedge [Re: HYPER8oSoNic] #1262753
08/05/12 09:37 PM
08/05/12 09:37 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
MB
3 tenths? Some "top-end" charge!!
If the wedge had WON, Mike you would have been about an "unfair advantage" - Too many CUBES!!
Nope.
Id love nothing better than to see Ed's Maxie take everyone down, but thats a tall order. I think were pretty happy where we are at considering the 50 year old 286 heads on Ed's motor (which were ported to the hilt), flow robably LESS than a typical street hemi head that is untouched. I do have a radically different cam that I want to try on the dyno before the fall swing. The motor is at my shop now undergoing a freshen up...We'll see...
Oh, and speaking of wedges , watch out for the white Firebird. Im hearing that its got some more smoke and has already gone 10.20's or thereabouts. Oh the humanity!
MB
Re: Hemi vs Wedge [Re: HYPER8oSoNic] #1262754
08/05/12 09:45 PM
08/05/12 09:45 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Mike,
I don't think that anyone with the exception of myself would have liked to see the wedge out run Dave's Hemi! Or even run with it?
The engine for the Maxie was just freshend up by Mike and I think I have found a little something in the car so maybe it will run a little faster this fall?
But there is no dought the Hemi just runs away from the Wedge upstairs.
Both where very close in power (within 10HP wedges advantage)?
Both cars weight the same?
Maxie runs 133 MPH and the Hemi 139MPH what am I missing???
Ed
Re: Hemi vs Wedge [Re: XXHEMI] #1262755
08/05/12 10:10 PM
08/05/12 10:10 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Mike,
Ed
Eddie
If you compare the two dyno sheets the answer lies there..
The Maxie makes its peak power relatively early then falls off pretty hard. The Hemi, on the other hand, makes its peak power at a higher RPM and really doesnt fall off. I'd be willing to bet Daves head flows 30% or better than the wedge head. Its all in the design and flow characteristics. Thats my .02 anyway....
MB
Re: Hemi vs Wedge [Re: HPMike] #1262756
08/05/12 10:38 PM
08/05/12 10:38 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Ed you must be forgetting about me. I am your biggest fan. I love your black Maxi. I would think with the displacment,cross section of the port combined with cross ram intake the torque curve is flat and broad. I would like to see how the car would do with a taller gear.
Getting old just means you were smarter than some and luckier than others.
Re: Hemi vs Wedge [Re: dannysbee] #1262757
08/05/12 10:51 PM
08/05/12 10:51 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Danny
Gear change is on tap. I let you know.
