Re: motor plate
[Re: earthmover]
#1262385
07/05/12 08:58 PM
07/05/12 08:58 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Use the one that Andy F sells thru Mancini and other sources.It's the best one out there.You can also get it as a solid plate to mount various parts to.
Re: motor plate
[Re: a493demon]
#1262387
07/05/12 09:16 PM
07/05/12 09:16 PM
The one on the left I made out of 3/8 thick aluminum and have since cut angles on the top to make it look good.
Re: motor plate
[Re: earthmover]
#1262390
07/06/12 08:55 AM
07/06/12 08:55 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
These are freeking awsome got mine at mancini's just set motor in and make up tabs i had my tranny mount in it's regular position then I moved it all back about .150. results Sets on the frame rails at the right height comes in A body or B body configuration See them Hear!!!!!! http://chucker54.stores.yahoo.net/moplstmi.html Think this is one of the easiest to install performance parts I ever bought! I did install studs on the water pump like andy said. Big thumbs up on this part! and a big thanks to all the guys on hear for the tips
Re: motor plate
[Re: earthmover]
#1262392
07/06/12 09:54 AM
07/06/12 09:54 AM
Posts: 16,928 NC
440Jim
NC
anybody have 1 they made can post pics..thanks mike
I agree the one piece is better than individual "elephant ears". This is all you need. The alternator can go either below, or above (stock location).
If you want to make one, get some dimensions and do it. But several companies sell them reasonable prices (~$100).
Re: motor plate
[Re: earthmover]
#1262394
10/12/12 02:10 AM
10/12/12 02:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a S&W BB plate that I'll sell if you want it... I had to build a custom one for my last customer... PM if interested
Re: motor plate
[Re: ]
#1262395
10/12/12 06:36 AM
10/12/12 06:36 AM
Posts: 9,865 MI, usa
dvw
MI, usa
All though this type isn't as trick looking, it depends what you have to mount. There's a lot of room for stuff. Not to mention you can tie it to down bars (which I should have done). Doug
Re: motor plate
[Re: dvw]
#1262396
10/12/12 06:37 AM
10/12/12 06:37 AM
dvw
MI, usa
Re: motor plate
[Re: dvw]
#1262399
10/13/12 12:30 AM
10/13/12 12:30 AM
Posts: 2,449 nc
earthmover
nc
