Fuel coming out of return line ????? #1262248
07/05/12 03:27 PM
07/05/12 03:27 PM
dark side of the moon
Dougsmopars Offline OP
My 68 GTX has the 5/16 fuel line and 1/4 return line. I don't use the seperator just an inline fuel filter. The return line is not used. Car has the 2 vent tubes installed look to be orignal. 3 years car has been fine. Yesterday went for a short ride stopped to get a coffee and saw fuel pooring out under the car. Opened the hood and saw fuel coming from the return line. Never did this before. What could be the problem? I plugged it off with a vac plug to stop the fuel for now. Just wondering why it was coming out of return line.
Re: Fuel coming out of return line ????? [Re: Dougsmopars] #1262249
07/05/12 04:24 PM
07/05/12 04:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Mainly because you don't have it hooked up right, would be my guess.
Put back like it was new and you won't have problems.
Re: Fuel coming out of return line ????? [Re: Challenger 1] #1262250
07/05/12 04:32 PM
07/05/12 04:32 PM
Explain? I didn't hook anything up. Car has been fine for last 3 years i've owned it. Tank and lines are orignal. Only thing changed was not useing the return line. Fuel line to pump to carb just like a 383 car. No vapor seperator so no 1/4 inch return used. Fuel is coming from tank out the end of return line under the hood. Wondering if vent tube is clogged?
Re: Fuel coming out of return line ????? [Re: Dougsmopars] #1262251
07/05/12 04:53 PM
07/05/12 04:53 PM
Not saying that is the cause but yes I'd check the vent tubes. I had a black rubber? cap on the return nipple on my bypass type filter & it sprung a leak after several months and I've had a red plastic type vac nipple cap on the return nipple port on the sending unit & no leaks after 5+ years
Re: Fuel coming out of return line ????? [Re: Dougsmopars] #1262252
07/05/12 05:06 PM
07/05/12 05:06 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
That would be your best bet, the factory vent lines (2) can be clogged up over the years for a variety of reasons. Dirt, undercoating, crushed tube, rubber deterioration, mud dauber wasps, etc. Your gas cap is non-vented otherwise it would leak gas every time you accelerated. With the gas cap holding pressure, the vent tubes are supposed to do that job. If they get glogged then the pressure build up has to go somewhere - out the return line. I would get comfortable underneath the front of the gas tank and trace your vent lines to see what the condition is. One line is pretty short, maybe 10", and the other goes up into the trunk, then over to the side and back down into the axle tunnel on the passenger side. In the picture, the vent lines are the two small ones over on the driver's side of the tank. Open the gas cap and give the vents a short burst of air. You should hear it inside the tank. Once those are open just plug off the existing return line. I had a mud dauber wasp close mine up years ago...
Re: Fuel coming out of return line ????? [Re: 68jim] #1262253
07/06/12 12:07 AM
07/06/12 12:07 AM
I'll check them tomorrow. Yesterday was first time i took the car out this year and first time it puked any fuel out the return line. Bug might have made a home in the vent tube while in storage over the winter.
Re: Fuel coming out of return line ????? [Re: Dougsmopars] #1262254
07/06/12 02:56 AM
07/06/12 02:56 AM
USA
540DUSTER Offline
540DUSTER  Offline
USA
If it is as warm on the dark side of the moon as it is in my neck of the woods,and you just filled your tank with gas that was in a cool underground tank.I would guess that the gas expanded and is overflowing out of the tank.
Re: Fuel coming out of return line ????? [Re: Dougsmopars] #1262255
07/06/12 07:53 AM
07/06/12 07:53 AM
Cincinnati, Ohio
Cincinnati, Ohio
That 1/4" "return" line is a vent line I believe. Because only 440/6 and hemis had return lines and they used 3/8" feed lines.
So yours being 5/16" I don't beleive your car had a return line. When not sure what to do with it, hook it up to the valve cover breather and that will keep the fumes down and allow your gas tank to vent and keep the bugs out.
