Re: I got the A/C working in my 71 Polara but.............
[Re: wasacuda]
#1261123
07/03/12 12:01 AM
07/03/12 12:01 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Cold water or hot water?
If it's cold water and the condensate drain isn't plugged then you probably have a bunch of ickies built up in the evaporator case. It can prevent condensate from getting out.
One of my techs at work had a plugged condensate line on his VW Caddy diesel. The system filled the A/C box with condensation and froze it. He had a frost line about 4" high on the side of his A/C box. The evap temp switch is apparently bad on his.
[Re: wasacuda]
#1261124
07/03/12 02:54 AM
07/03/12 02:54 AM
Posts: 106 waco tx
gogo318
waco tx
could be a cracked or broken drain pan that is assuming its cold water
67 charger fastback 318 stock
67 belvedere II 4dr soft top built 318
68 newport 2dr hard top 318
84 b150 440/727
84 d150 short wheel step side 4x4 lifted
87 omnitruck (you just have to see it )
new addition 63 dart wagon !!!
