Do I Have A Broken Piston Wrist Pin?
#1261058
07/02/12 10:28 PM
07/02/12 10:28 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
RE: 1996 408 Magnum
Back in the fall, it ate a piece of metal. The resulting carnage was 2 bent valves and pushrods in #3, 2 wiped out cam lobes, a scarred combustion chamber, and a couple of nicks in the top of the piston. I replaced all the broken parts and had a machine shop clean up the cylinder head. I was able to clean up the top of the piston with emory cloth. I put it back together and it sounded like can of marbles. So I tore it apart again and this time, the #8 intake lifter broke (and remember its a roller lifter) and tore the new cam up. I'm willing to write that off as either a bad lifter or I installed the cam, rocker or valvespring in wrong.
So now Im on camshaft #3 with a brand new set of lifters. Now it sounds like marbles again and it sounds like the valvetrain but Im trying to rule it out. So now my plan is to pull the oil pan and inspect the rod, wrist pin and piston skirt.
Am I on the right track? I feel like after going through the valvetrain 3 times I should rule it out. Remember I have not looked at anything below the top of the piston but I listened to it with a mechanics stethoscope and it sounds like the battle rattle is coming from the top.
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
Re: Do I Have A Broken Wrist Pin?
[Re: RSNOMO]
#1261060
07/02/12 10:38 PM
07/02/12 10:38 PM
RangerDan440
I did that a long time ago, its holding compression in every cylinder except for when it first broke and the valves and pushrods were bent
[Re: RangerDan440]
#1261062
07/02/12 10:45 PM
07/02/12 10:45 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'm pretty sure he was asking you to pull the wires to see if the sound changes not if it misses When you pull the wire there is no explosion in the cylinder therefore it will indicate where your noise is. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: RSNOMO]
#1261063
07/02/12 10:46 PM
07/02/12 10:46 PM
RangerDan440
Yes it ticks whether the cylinder fires or not
[Re: RangerDan440]
#1261065
07/02/12 10:55 PM
07/02/12 10:55 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
A loose wrist pin or a scuffed skirt will give a double rap on decel if you rev it up in neutral and chop the throttle
Kevin
[Re: Twostick]
#1261066
07/02/12 10:58 PM
07/02/12 10:58 PM
RangerDan440
this has an intermittent tapping, like it skips a tap on maybe on every 3 or 4 strokes.
