Harland Sharp rocker shafts
#1260375
07/01/12 04:47 PM
07/01/12 04:47 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I use Crane ductile iron rockers and Crane rocker shafts on my 505 and noticed a few marks on the shafts the last time I had them off. So I just ordered a pair of Harland Sharp thick wall hardened rocker shafts because they looked like the best replacements available. I just read that these shafts have the oil hole drilled right through, i.e. there's a hole at the top and the bottom of the shaft. I guess you couldn't use these with stamped steel rockers but am I ok using them with the Crane rockers?
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
Re: Harland Sharp rocker shafts
[Re: robnbird]
#1260378
07/02/12 03:46 PM
07/02/12 03:46 PM
Mick70RR
Birmingham, England
Thanks for the replies. Sounds like I should be ok using the Crane rockers on these shafts. The HS rockers are a bit of an overkill for my valve lift but I may get them later on.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
[Re: Cab_Burge]
#1260381
07/02/12 06:43 PM
07/02/12 06:43 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The harlam sharp shaft have a banana slot cut across the bottom oil hole. the hardened steel shaft is for using the roller brgs on the harlan sharp rockers.
There are no banana grooves on BB rockers unless they've changed.
HS shafts are made for their roller bearing rockers - apparently NOT hard-chromed. Other non roller bearing sharfts are apparently hard chromed.
Either way, I can't see the oil holes being an issue.
[Re: Stanton]
#1260382
07/07/12 03:49 PM
07/07/12 03:49 PM
Mick70RR
Birmingham, England
Got the shafts on Thursday, the oil holes on the top and bottom are the same size and no banana groove. Spent a few days on the lathe making new spacers and hold downs to replaces the springs and stock hold downs and got it back together this morning. Oil pressure is as it was before and there's plenty getting up top.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
[Re: Stanton]
#1260385
07/08/12 07:38 AM
07/08/12 07:38 AM
Mick70RR
Birmingham, England
The hold downs and spacers are steel and the picture was taken before I set the lash so the studs are right out.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
