Bulkhead connection diagram?
#1260135
06/30/12 11:27 PM
06/30/12 11:27 PM
Posts: 6,480 Kingston, IL USA!
gts340swinger
Kingston, IL USA!
I have a 68 Barracuda that I am having trouble with. The fuseable link melted and left me stranded the first time out this year. I am finally getting a moment to take a look at it and see what's up. I found the link melted and also a crispy connection for a large gauge wire that has replaced a wire from the alternator I believe, bypassing the factory harness wire and going to the amp gauge I assume. This wire seemed to have a poor connection causing resistance and heat, possibly causing the fuse link to melt. I replaced the bad connection and also the fuse link with 18g fuse link wire. The socket on the bulk head was crispy as usual so I made something work for now. As soon as I hooked up the battery I instantly melted the new fuseable link again, with the key off. Long story but I wonder what has been moved around by the previous owner and I want to look at a diagram of the bulk head connections so I can sort this out. Could be the connection on the gauge I assume. Any help is appreciated.
Mr. Norm's "Fanatic" (idiot) 71 Mr. Norm's Demon GSS 77 Mr. Norm's personal B250 GSS van 76 Mr. Norm's KZ900 Motor Sports Special 69 Mr. Norm's M code Dart GTS 69 D100 68 Barracuda 64 Valiant V200 07 Charger Daytona SST 6 speed test mule.
Re: Bulkhead connection diagram?
[Re: gts340swinger]
#1260139
07/01/12 12:41 AM
07/01/12 12:41 AM
RapidRobert
likely something moved/shifted to where it's permanently grounded/touching now. I'd start at the bulkhead fusible link in & work toward the ammeter & beyond to the splice where it T's to the lights/fuse box/ign switch. The melted insulation may help you pinpoint where it's grounded
[Re: RapidRobert]
#1260140
07/01/12 11:58 AM
07/01/12 11:58 AM
gts340swinger
Kingston, IL USA!
I think I'm just going to take it apart and re do everything related to it. I want my wife to be able to drive the car without worrying that it will leave it stranded.
[Re: JohnRR]
#1260142
07/01/12 09:37 PM
07/01/12 09:37 PM
gts340swinger
Kingston, IL USA!
Check the amp gauge, a quick way to see if it is the problem is just to disconnect the 2 wires and put them together if all is ok the amp guage has shorted to the dash cluster. This happens because the studs are just insulated by a cardboard strip that crumbles and falls off, the gauge studs shift and short out against the gauge cluster.
That could be the case too. The gauge was fluctuating a lot just before failure. I mashed the gas, hit second gear and poof! Done. Some of the lights didn't work before hand. I'm almost afraid to see what it looks like.
