MT ET Streets. When are they done? #1260095
06/30/12 10:58 PM
06/30/12 10:58 PM
Near Reading PA USA
pinkduster Offline OP
Near Reading PA USA
Like the title states. The Mickey Thompson ET Street bias tires. When is it time to replace them? I have had barely any tread showing for quite some time now. Tech has never said anything about them at Cecil. Last month, at the Grove, the tech guy said I need 2/32s, but let me race anyway. So after two days of racing, there is no longer any sign of tread. I guess it's time to buck up for new ones?
How long have you used them? Does 60ft. go away at some point?
Re: MT ET Streets. When are they done? [Re: pinkduster] #1260096
07/01/12 01:38 AM
07/01/12 01:38 AM
My last set went into the cords at the track Can you post a picture of yours now? I run both the ET Street Bias plys and ET STreet Radilas, the radials will go a long ways and still hook outstanding after the center tread grooves are gone BTW, I have not run the radials into the cords, maybe close now on one set of 296x65x15, not on any others so far
Re: MT ET Streets. When are they done? [Re: pinkduster] #1260097
07/01/12 01:39 AM
07/01/12 01:39 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I just ordered a set my self.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: MT ET Streets. When are they done? [Re: hemi-itis] #1260098
07/01/12 01:42 AM
07/01/12 01:42 AM
Those look like Sportsman Pros or Pros, not ET Streets
Re: MT ET Streets. When are they done? [Re: Cab_Burge] #1260099
07/01/12 01:47 AM
07/01/12 01:47 AM
hemi-itis Offline
hemi-itis  Offline
Right you are Cab,but you'll notice they are DONE!They were usless for me,but I squeezed 3 seasons out of them I am trying the bias E/T streets looking for traction on the street
Re: MT ET Streets. When are they done? [Re: hemi-itis] #1260100
07/01/12 02:33 AM
07/01/12 02:33 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Thats when the Sportsmans Pros work the best - almost no tread lines to where the cord shows.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: MT ET Streets. When are they done? [Re: Evil Spirit] #1260101
07/01/12 11:34 AM
07/01/12 11:34 AM
hemi-itis Offline
hemi-itis  Offline
They NEVER hooked for me.You can have them
Re: MT ET Streets. When are they done? [Re: hemi-itis] #1260102
07/01/12 01:45 PM
07/01/12 01:45 PM
I don't know anyone who has some power that could hook on the Pros or Sportmans Pros The ET Streets are another subject altogether, neck snapping acceleration The tire lifes is determined by the driver
Re: MT ET Streets. When are they done? [Re: Cab_Burge] #1260103
07/01/12 03:34 PM
07/01/12 03:34 PM
hemi-itis Offline
hemi-itis  Offline
Cab,are you sayin' that I might acually finally get traction in the street???? .....wait
Re: MT ET Streets. When are they done? [Re: hemi-itis] #1260104
07/01/12 03:41 PM
07/01/12 03:41 PM
Near Reading PA USA
Near Reading PA USA
I find that the ET Streets have MINIMAL more traction than a regular tire on the street. I can blow them off like a John Force burnout if I take off like I do at the track. But on well prepped track, they work great for me. So Hemi itis, don't expect miracles with your new tires.
Re: MT ET Streets. When are they done? [Re: pinkduster] #1260105
07/01/12 03:50 PM
07/01/12 03:50 PM
hemi-itis Offline
hemi-itis  Offline
Geee,,,,,,,,,,,,,thanks
Re: MT ET Streets. When are they done? [Re: pinkduster] #1260106
07/01/12 10:48 PM
07/01/12 10:48 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
for me it all depends on pressure. On the street I run them at 25-30psi, and they will spin up a bit with my weak smallblock, but at 16-17 at the track, they hook great. No input as to when they are "done" this is the first set of ETs I've had.
That being said, anyone I know that ran sportmans/pros was never able to hook with them
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: MT ET Streets. When are they done? [Re: OUTLAWD] #1260107
07/01/12 10:55 PM
07/01/12 10:55 PM
hemi-itis Offline
hemi-itis  Offline
How about backing into your own rubber,anyone try that yet??
Re: MT ET Streets. When are they done? [Re: hemi-itis] #1260108
07/01/12 11:03 PM
07/01/12 11:03 PM
Probally a lot more than you have now with those(Pro or Sportsman Pros) tires on their best day I can spin them on the street, 13.5x30x15 with 15+ lbs in them, they dead hook at 9.0 to 11.0 lbs at the track, 1.41 60 ft. times. If I run 10 lbs on the street they will spin a little and then hook. The ET Street Radials of the same size will not hook on the street with my car The radials are faster at the track(1.39 60 ft last weekend ), when it is good, than the bias plys are If the track is bad the bias plys are easier to drive and race on
Re: MT ET Streets. When are they done? [Re: hemi-itis] #1260109
07/01/12 11:11 PM
07/01/12 11:11 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Yeah, I tried it. I did a 10 second tire melting burnout and laid down 50 feet of melted rubber down on the highway on a hot day then backed onto my tracks with my 26x11.5 et streets @ 15 lbs. Net result was worthless, My typical 4500 rpm launch that I can occasionally hook here and there turned into 200' of tire stripes- so for me- there was no gain in traction.
Re: MT ET Streets. When are they done? [Re: Evil Spirit] #1260110
07/01/12 11:33 PM
07/01/12 11:33 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
My car will usually run the same 60' on a set of 28x13.50 ET Streets as a set of 28x10 slicks - 1.50-1.52. A new set of 28x13.50 Sportsman Pro's start at 1.70 and stay there till the tread is gone, then I can get 1.55-1.57's out of them. I even got a couple of 1.57's out of a set of "worn out" 28x10.50 Pros a buddy had thrown away. As to tread life, the ET Streets last at least twice as long as the Sportsman Pro's do.
Now for the bad news. Once I went to 325/50/15 MT Drag Radials I'll never go back to a bias ply tire. I can run the same 1.50 60's and the radials feel soooooo much better on the street and top end - none of the bias ply wander and pretty good tread life.
BTW my Signature pic (see attachment) is a 1.51 60' on a set of 26x9 slicks, with only about 7 1/2PSI due to a faulty gauge. Left hard, but would try to do the "Hamster Dance" at about 120+.
7273590-Spirit2.pdf (103 downloads)
Re: MT ET Streets. When are they done? [Re: 72demon416] #1260111
07/02/12 10:24 PM
07/02/12 10:24 PM
hemi-itis Offline
hemi-itis  Offline
Thanks,they did not come in yet but that's what I will try.I still need to buy new belts and recert the car.
