Re: what wheel size will fit?
[Re: 440 trucknduster]
#125996
09/25/08 12:26 PM
09/25/08 12:26 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If it seems no one is paying attention it is because the same question has been asked way too many times in the last month. Do some work and do a search if it seems to be a common question. I believe your MOPAR and most later mopars use 5 on 4.5 bolt pattern which shares the same pattern as the Ford and not like the Chevy pattern. Look here for other wheel related questions http://www.moparts.org/Tech/Archive/wheels/1.htmlAlso look here for other commonly asked questions and reference material http://www.moparts.org/Tech/
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Dart 340]
#125998
09/25/08 05:00 PM
09/25/08 05:00 PM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
If the rear of your does not sag a 15x10 w/ 4" back space and a 275/60/15 will fit and look awsome. I did this on a '73 I had.
So the bartender says to the horse " Gee, Why the long face?"
[Re: eagles]
#126000
09/26/08 08:13 PM
09/26/08 08:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Well with B body axles in a 75 Duster with the springs in the stock location and the perches on the rear moved in to accommadate the springs I can use a 10X15 with 5 inch back spacing. Oh by the way are real sure that you don't have 4 1/2 inch standard bolt pattern. BTW it isn't the wheel that you will have to worry so much about it is the tire size and tire bulge that will get you. With mine I didn't want to take a corner to hard with 10.5 tires.
#126004
09/27/08 08:18 AM
09/27/08 08:18 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
i have a 74 duster 8 and a 1/4 rear end, will a set of 15x 10 rims fit on the back and clear my fender lips? with a back spacing of 3.5? and bolt pattern is 5 on 5? if this is not rite? what will work?? help
15X10, is pretty wide with out tubbing and shortening the rear. 3.5" back spacing will put the rim way out past the 1/4, you need 4.25 or 4.5" with the stock rear and wheel tubs, You also need a 4.5" bolt pattern, not 5.5"
[Re: MoparforLife]
#126006
09/27/08 09:46 AM
09/27/08 09:46 AM
AdamR
Bethel Ct
My reply above about the 4.5 bolt pattern could be misleading in the fact that it could be a 4 inch if the car is a low line model with drum brakes all around. Disc brake A bodies (about 72 or & 73 up?) were equipped with the 4.5 inch bolt pattern hubs drums and wheels. Never 5 inch.
Good catch Don, I made the same mistake also.
[Re: AdamR]
#126007
09/27/08 10:12 AM
09/27/08 10:12 AM
MoparforLife
Upper Midwest
It was something different from me too. I am usually the one reads faster than my old mind works and either miss or read something else into it. Gettin' old ain't fun.
