no responce from key turn #1259275
06/29/12 06:33 PM
06/29/12 06:33 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Having trouble with my 72 Challenger 360 engine.. key buzzer goes on.. all lights work, seems to be plenty of battery power.. sometimes I would hear a click, or spuratic clicks, then i would try it again and it starts fine.. now i get no sound or any responce.. turn the key to start and nothing.. doesn't seem to be making it to the starter, I have one of those tiny replacement starters in there now to fit in next to the headers i put in.. the original was just way to big.. anyone know where i should look or advice.. thanks
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: no responce from key turn [Re: Caparco] #1259276
06/29/12 06:47 PM
06/29/12 06:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try holding the key in the start positiion and move the shifter from park to neutral and see what happens. It could be as simple as a linkage adjustment.
Re: no responce from key turn [Re: Caparco] #1259277
06/29/12 06:48 PM
06/29/12 06:48 PM
make sure all the large cable terminals/posts are clean both the positive and negative. If no go jump the "grn" terminal on the starter relay to ground & see if it cranks. try Stumpys trick of holding the key to start and moving the shifter (if automatic) thru all the positions
Re: no responce from key turn [Re: RapidRobert] #1259278
06/29/12 06:51 PM
06/29/12 06:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it is an auto be sure the neutral safety swith plug is on the trans tightly.
Re: no responce from key turn [Re: stumpy] #1259279
06/29/12 07:03 PM
06/29/12 07:03 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
it is a auto yes.. no responce from holding the key forward and shifting into neutral.. I will have to clean the terminals and see, where is that safty relay on the trans?.. i never heard of that one
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: no responce from key turn [Re: Caparco] #1259280
06/29/12 07:21 PM
06/29/12 07:21 PM
Starter relay on the drivers fender or firewall. Neutral safety switch on the drivers side of the trans, an electrical plug in
Re: no responce from key turn [Re: RapidRobert] #1259281
06/29/12 07:35 PM
06/29/12 07:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Neutral switch supplies the ground for the starter relay when in park or neutral. It also is what makes the back up lights come on in reverse. It's the three prong connection on the trans. Center terminal is ground and the two outside terminals are in and out for back up light power. http://www.moparts.org/Tech/Archive/auto/5.html
Re: no responce from key turn [Re: RapidRobert] #1259282
06/29/12 07:36 PM
06/29/12 07:36 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
prob. the contacts in the solinoid and plunger are bad on the mini starter . you can just replace those .
Re: no responce from key turn [Re: a493demon] #1259283
06/29/12 07:43 PM
06/29/12 07:43 PM
a493demon Offline
a493demon  Offline
to test it you can make sure you are getting a signal at the small wire on the starter with a test light.if the test light lights up when you turn the key to crank most likely the contacts in the solinoid.
