no responce from key turn
#1259275
06/29/12 06:33 PM
06/29/12 06:33 PM
Posts: 59 Rhode Island
Caparco
Rhode Island
Having trouble with my 72 Challenger 360 engine.. key buzzer goes on.. all lights work, seems to be plenty of battery power.. sometimes I would hear a click, or spuratic clicks, then i would try it again and it starts fine.. now i get no sound or any responce.. turn the key to start and nothing.. doesn't seem to be making it to the starter, I have one of those tiny replacement starters in there now to fit in next to the headers i put in.. the original was just way to big.. anyone know where i should look or advice.. thanks
~ 72 Dodge Challenger ~ ~ 97 Dodge Neon ~ ~ 97 Dodge Ram ~
Re: no responce from key turn
[Re: Caparco]
#1259277
06/29/12 06:48 PM
06/29/12 06:48 PM
RapidRobert
make sure all the large cable terminals/posts are clean both the positive and negative. If no go jump the "grn" terminal on the starter relay to ground & see if it cranks. try Stumpys trick of holding the key to start and moving the shifter (if automatic) thru all the positions
[Re: stumpy]
#1259279
06/29/12 07:03 PM
06/29/12 07:03 PM
Caparco
Rhode Island
it is a auto yes.. no responce from holding the key forward and shifting into neutral.. I will have to clean the terminals and see, where is that safty relay on the trans?.. i never heard of that one
[Re: Caparco]
#1259280
06/29/12 07:21 PM
06/29/12 07:21 PM
RapidRobert
Starter relay on the drivers fender or firewall. Neutral safety switch on the drivers side of the trans, an electrical plug in
