Re: electric fan / cfm
[Re: werty]
#1259232
06/29/12 01:29 PM
06/29/12 01:29 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Werty, Is it set up as a pusher or a puller? 2500 cfm, should be more then adaquete for your set up.
If you have it as a pusher I would suggest setting up as a puller, them add a shroud.
JMO
Mike
1969 Dodge Dart Swinger
[Re: MikeyT]
#1259233
06/29/12 01:44 PM
06/29/12 01:44 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Your fan should be adequate or at least nearly adequate if it is set up as a puller. A shroud would help as well to direct the airflow. If your engine is raising by 30 or 40 degrees just from stopping at two lights, then I think you may have something else that's causing the motor to run hot. Maybe timing or mixture? I am assuming the WP is in good shape but might be something to check. Maybe pinch the hoses (wear gloves) and see if you feel the water flowing? I have a set of dual 11's on my Charger rated at 2670 CFM together and they cool my BB stroker motor all day at 180-190 degrees....even sitting idling on a hot day...
[Re: werty]
#1259234
06/29/12 03:36 PM
06/29/12 03:36 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
There is no calculation for cfm. It depends on too many things such as blade design, shroud, grille, physical motor size, etc. If you're going to use electric fans they MUST pull some amperage. If the motor isn't pulling power it isn't moving air. The fans you find at the parts house are good for supplemental cooling but should not be relied on for primary cooling. How many of those cheap crappy things do you see factory installed in cars? NONE!
If you have the room, go with a Mercedes fan upgrade on a 26" radiator. It's been discussed here at great length.
If you don't have room for that or are using a smaller radiator, go back to the factory shroud and thermal fan clutch.
[Re: ahy]
#1259236
06/29/12 08:26 PM
06/29/12 08:26 PM
feets
Senior Management
Senior Management
Irving, TX
The reason some of us like the Mercedes fan is the volume of air it moves. It's almost disturbing. The HHR and Taurus fans are puny by comparison. Yes, it's more expensive but if you use it there should never be another problem with air flow.
[Re: feets]
#1259237
06/29/12 08:39 PM
06/29/12 08:39 PM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
I plan on going to the Mercedes fan route, but I think I will need to go to the Denso alternator first.
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
[Re: Mad_Scientist]
#1259238
06/29/12 10:17 PM
06/29/12 10:17 PM
feets
Senior Management
Senior Management
Irving, TX
If you run hooziewhatsit's controller you'll be fine with a 78 amp square back alternator. That really cuts down on the fan's electrical consumption. There should be very few times when it's running at 39 amps. The lower speeds draw far less amperage and will cool most cars even with A/C running.
One thing I should have elaborated more on earlier is the cfm rating of fans. There is no industry standard on cfm ratings. Manufacturers will run their fans with a perfect electric feed and with no restrictions in the way. That results in a perfect world rating. In the real world, there's a radiator in the way and a less than perfect electric feed. The fan will have to work harder to reach it's maximum speed and maximum air flow. If there's not enough motor, there's not enough air flow. having enough motor means you will be pulling a minimum of 30 amps to get the fan running. If your fan suggested a 20 amp fuse it's not going to move much air. Another way to tell is if the fan has a 10 gauge or smaller wire on it. 12 gauge wire will get hot running a continuous 20 amps. A typical 10 gauge wire will get hot running 30 amps.
