Electronic Ignition System Problems #1259080
06/29/12 12:50 AM
06/29/12 12:50 AM
Sin City
calif67rt Offline OP
Sin City
I have a 1967 Dodge Coronet R/T, 440 motor with a mild cam, 2 fours, 2-1/2 inch headers and 727 trans. The ignition system was changed to a Chrysler electronic system years ago. Several months ago, when I tried to start the motor, it would crank but not start. It was not getting fire to the plugs. When I turned the ignition switch completely off, the motor would ‘jump’ and act like it would backfire (it did a couple of times). Eventually it would start, after I pulled off and put back on the coil wire between the coil and distributor cap.
I have since changed the ignition switch, ballast resistor, and control module. But I still have the same problem except now it won’t start at all. What could be the problem and how do I solve this, short of putting on a $900 MSD, or the like, ignition system?
Thanks for your help.
Re: Electronic Ignition System Problems [Re: calif67rt] #1259081
06/29/12 12:59 AM
06/29/12 12:59 AM
Wisconsin
moparkid88 Offline
moparkid88  Offline
Wisconsin
I would check and make sure all your grounds are good. Also I think the box itself should ground to the firewall...
1973 Charger SE 1987 Ram 4x4 lifted 318 4spd 1984 Ram 4x2 mild 360 1995 Neon 2.0 w/bolt ons
Re: Electronic Ignition System Problems [Re: calif67rt] #1259082
06/29/12 01:21 AM
06/29/12 01:21 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I'm no good at troubleshooting these things, but if the ECU, ballast, and coil are known to be good, what about a bad pickup coil in the distributor or perhaps the wrong gap between pickup coil and reluctor? IIRC, the gap should be .008" (with a brass feeler gauge), but others can chime in - my FSM's not handy right now.
Re: Electronic Ignition System Problems [Re: MoparMarq] #1259083
06/29/12 01:26 AM
06/29/12 01:26 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I suspect pick up as well.
Mike
1969 Dodge Dart Swinger
Re: Electronic Ignition System Problems [Re: calif67rt] #1259084
06/29/12 10:19 AM
06/29/12 10:19 AM
Sin City
Sin City
I am thinking it could be the pickup coil also but I wasn't sure if the whole distributor needs to be replaced. When it runs, it runs well. I will change the pickup coil and also check all of the grounds when I get back. (Having to work out of the area for now.)
Thanks for all of the info.
Re: Electronic Ignition System Problems [Re: calif67rt] #1259085
06/29/12 11:23 AM
06/29/12 11:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Also check the gap of the pickup in the distributor .
Re: Electronic Ignition System Problems [Re: calif67rt] #1259086
06/29/12 12:58 PM
06/29/12 12:58 PM
pa.
dan9 Offline
dan9  Offline
pa.
I just had the same issue yesterday with my 69 RR with electronic ignition. It was the coil.
Re: Electronic Ignition System Problems [Re: calif67rt] #1259087
06/29/12 09:16 PM
06/29/12 09:16 PM
take off the yellow "ign" wire from the starter relay to disable the starter. seperate the 2 wire dist pickup connector. Coil secondary wire (dist end) held 1/4" from a ground. Have a helper hold the ign key to start as you touch/break the male end of the eng harness half of the dist pickup connector to ground repeatedly like Morse Code & see if the coil wire sparks. If so all is good in the 'hood except for the dist pickup/reluctor/connector wiring. Everything can test good when cold then act up continuiously or intermittently when hot but this may help you get started.
