Re: how can i keep my demon from running hot
[Re: moparmafia]
#1258993
06/28/12 09:17 PM
06/28/12 09:17 PM
Posts: 1,770 Wethersfield,CT
Ray440
Wethersfield,CT
Start with the basics. Does the system hold pressure? Do you have a spring in the lower hose to keep it from collapsing? Thermostat stuck?
1969 Plymouth Road Runner 440 auto 2017 Ram 1500 Quad Cab 5.7 Hemi
[Re: poisondart2]
#1258997
06/28/12 10:01 PM
06/28/12 10:01 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Get your self a set of spal twin 11" fans. This will cure your problem. I drive mine all over in rush hour traffic not a problem. This is with a 422 cu in small block.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: poisondart2]
#1258998
06/28/12 10:04 PM
06/28/12 10:04 PM
Ray440
Wethersfield,CT
Does the heater work OK? Heater core not plugged up? What's the timimg set at at idle? sometimes to much initial timing at idle can cause overheating issue.
[Re: moparmafia]
#1259001
06/28/12 11:12 PM
06/28/12 11:12 PM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi 185 at speed tells us you need to check your Low speed circulation and air flow ! what water pump r u using ? pulley combo ? look in rad whith engine warm , is it circulating at idle ? pump speed may b a little slow ? what timing settings and curv are you using ? idle speed ? stall speed ? trany cooler ? ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: Ray440]
#1259003
06/29/12 09:17 AM
06/29/12 09:17 AM
1967dartgt
Hilltown Pa
I run my car with the distribtor locked out at 36 degrees. Spals come with shroud so make mounts you are good to go. I use them, my buddy with a 555 bbc now uses them after his 16 in puller would go to 215*. My other buddy uses them in his shoebox nova 406 sbc with f2 procharger.(711 rwhp) My other buddy uses then in his 499 69 dart. We all drive on the street alot and do not have overheating issues.Spal 11" fans and 26x19 raditors are the only thing we have in common.We all have elctric water pumps too.
