71 cuda rocker molding clips #1258903
06/28/12 05:22 PM
06/28/12 05:22 PM
Chicagoland
cudastruction Offline OP
Chicagoland
Does anyone know where I can find the little pins that are attached to the rocker panel that the molding clips attach to?
Al
Re: 71 cuda rocker molding clips [Re: cudastruction] #1258904
06/28/12 06:35 PM
06/28/12 06:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC the clips are held in place with a "nail head" stud, they're installed with a stud gun (welded on) your best to find a "buddy" or bodyshop that has a stud gun welding unit that you can borrow...
Re: 71 cuda rocker molding clips [Re: DAYCLONA] #1258905
06/28/12 08:09 PM
06/28/12 08:09 PM
Chicagoland
Chicagoland
That is how they were originally put on but doesn't somebody sell an "aftermarket" substitute that can be a screw style?
Re: 71 cuda rocker molding clips [Re: cudastruction] #1258906
06/28/12 09:03 PM
06/28/12 09:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You could substitute a PAN HEAD screw?.....
Re: 71 cuda rocker molding clips [Re: DAYCLONA] #1258907
06/29/12 11:28 AM
06/29/12 11:28 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
You have to use screws as mentioned.
MLR426
Re: 71 cuda rocker molding clips [Re: MLR426] #1258908
06/30/12 02:47 AM
06/30/12 02:47 AM
Jacksonville, FL
burnt_o_matic Offline
Jacksonville, FL
Or these...
CLIP STUD SCREWS
Re: 71 cuda rocker molding clips [Re: burnt_o_matic] #1258909
07/01/12 08:43 AM
07/01/12 08:43 AM
Chicagoland
Chicagoland
That's what I was thinking. Thanks!
