New 470 build needs your help!!! #1258452
06/27/12 07:35 PM
06/27/12 07:35 PM
Ruther Glen, Virginia
DanteGray Offline OP
Your opinions will be in this build!
Hey all Im starting a 470 build and want opinions on parts and recommendations. This is my prep for when I go to Carlise in July. My budget is 7000 and I have a few parts. 400 block, Mopar M1 4150 flange, MSD 6AL, Malory distrubator. The goal is low to mid 10s in a duster 3100 lbs with driver and 26 tall 12wide tire 3.73 rear (equal to 28/ 4.10). Fuel will be 93 pump and no NOS. There are no power acessorys (brakes, steering, ac).
Im thinking about buying:
Indy EZ440-1 preped heads and custom cam (maybe 620-630ish lift ultradyne). 3.915 stroke, 6.760 rod, 1.270 dish probe piston = 1.72 ratio; light weight piston (600g w/ pin) and long rod (9.9875 on 9.980 deck), 950 quick fuel or HP. between 3500-4k stall. Headman headers.
The goal is to be a street terror cause I'm tire of these damn chevys guys running their mouth!
Re: New 470 build needs your help!!! [Re: DanteGray] #1258453
06/27/12 07:40 PM
06/27/12 07:40 PM
fresno ca
mikeysmopars Offline
fresno ca
You need Thumperdart!
I would have said not doable but I am now a believer!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: New 470 build needs your help!!! [Re: mikeysmopars] #1258454
06/27/12 07:51 PM
06/27/12 07:51 PM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
Call Bob George, Indy has 470 rotating kits for a nice price! I ran one of the Indy kits for 2 years with zero issues. Eagle 4340 crank eagle h beam rods and Wisco pistons.
Re: New 470 build needs your help!!! [Re: 68valiant68] #1258455
06/27/12 08:52 PM
06/27/12 08:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That will not be to hard. Thats close to my 493 build and I have hit 10.70's at 3700 lbs with only 7 passes on it so far and I race it as I drive it on 92 pump through the full exh system. I used a 440Source 4.15 kit and dished pistons for pump friendly 10.6 comp. Heads are Indy EZ heads worked by Dwayne Porter and a solid flat tappet cam speced by Dwayne also. I am using the Indy dual plane intake with an 850 DP and a Mallory dist.
I would call Dwayne Porter for your heads and cam. I bought my heads and cam right from him as he worked the heads some and speced out a nice cam for the combo. And his prices are fair and he is a nice guy who is easy to work with. I think I have 10.50's in mine if I ever get to some serious tuning and maybe try a dominator carb. Good luck , Ron
Re: New 470 build needs your help!!! [Re: 383man] #1258456
06/27/12 09:12 PM
06/27/12 09:12 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I would go with a 1.32ch piston and a 6.535 rod. Only because that doesn't require ring support rails. Also ross makes a 1.32 piston that's right around 520 grams. The chevy rods are also cheaper and lighter, and more choices with 2.2 journal.
But your idea will work just fine too I imagine. Keep us posted. I like the 470 idea.
Re: New 470 build needs your help!!! [Re: 68valiant68] #1258457
06/27/12 09:13 PM
06/27/12 09:13 PM
V
viperblue72 Offline
viperblue72  Offline
V
The Indy kit has 440 counterweights. Id go 440source with the chevy width journals.
Re: New 470 build needs your help!!! [Re: mikeysmopars] #1258458
06/27/12 10:17 PM
06/27/12 10:17 PM
Arizona
Chris'sBarracuda Offline
Arizona
If Thump Man would tell his secrets to you...
Dom's car certainly runs well.. 9.70's with RPM heads..
Chris..
Re: New 470 build needs your help!!! [Re: viperblue72] #1258459
06/27/12 11:12 PM
06/27/12 11:12 PM
Agreed, the 440 source style kit was my second option. But I'm staying with the 220 journal and .990pin chevy set-up. I just want to stay with a light weight piston so it will rev fast. Oh the Cam will be a solid flat tappet.
Re: New 470 build needs your help!!! [Re: DanteGray] #1258460
06/27/12 11:22 PM
06/27/12 11:22 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I assume Muscle Motors still does these. They did mine and it's a 1.32ch piston and a 6.535 rod combo and it revs fast. Mine is 10:1 compression, Bulldog heads, 585 lift 259@.050 cam, RPM intake and a MD 850 (stay away from that carb )
470 in a light car should be fun.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: New 470 build needs your help!!! [Re: DanteGray] #1258461
06/28/12 12:05 AM
06/28/12 12:05 AM
If your buying new heads buy the the Max Wedge intake ports EZ, sell the M1 intake and buy a used Indy single four intake, 4150 or 4500 flange with the max wedge intake ports, both work well with adapters or spacers with the Quik Fuel or Holley 950 H carbs, the Quick Fuel is bigger CFM than the Holley is and shoot for close to 255 to 265 duration at .050 with as much lift as you can get on the cam and have it ground on 108 lobe centers, install it 3 to 6 degrees advanced on the intake lobes I've built and help build several 3.91 stroke motors, both high deck and low decks, they will run
Re: New 470 build needs your help!!! [Re: Sledge_57] #1258462
06/28/12 02:35 AM
06/28/12 02:35 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I assume Muscle Motors still does these. They did mine and it's a 1.32ch piston and a 6.535 rod combo and it revs fast. Mine is 10:1 compression, Bulldog heads, 585 lift [Email]259@.050[/Email] cam, RPM intake and a MD 850 (stay away from that carb )
470's are FUN. I'm just beginning to have fun with mine in a 67 Coronet.... check out my recent post... you just miiiiiiight be interested in my build since you have a lighter car than mine
Re: New 470 build needs your help!!! [Re: 67dodge67] #1258463
06/28/12 03:04 AM
06/28/12 03:04 AM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
6.7 rod uses 1.32cph muscle motor combo
6.535 rod uses 1.485 cph 440 source
or u can us 6.385 rod with 1.665 cph Scat makes nice I beam cheap
check out Ramm's post 470 on the dyno 670 horse on pump gas looks like pretty straight foward parts that made great power!
Re: New 470 build needs your help!!! [Re: 71Pan] #1258464
06/30/12 02:00 AM
06/30/12 02:00 AM
V
viperblue72 Offline
viperblue72  Offline
V
Good catch! . I said 6.535 rod with 1.32, its actually 6.7.
Re: New 470 build needs your help!!! [Re: viperblue72] #1258465
06/30/12 08:13 AM
06/30/12 08:13 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I'd say the only downside of your build is the lack of stall. My car is 3100# 440 RB, more comp than you 12.5.1, more stall 5000 but less head cubes and cam. So low 10's should be easy enough.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: New 470 build needs your help!!! [Re: deaks] #1258466
06/30/12 12:28 PM
06/30/12 12:28 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
if my 440 can run low 10.20 as a 30 over 440 with old indy heads flowing around 330cfm and a 262@50 cam 640ish lift a 470 should have that covered.
our street stock pulling class has a 470 cid limit and i was thinking on that to try and use my 440-1c heads and hope the 30 extra cid helps the ported heads to make torque.
for a car to drag race i my self think the shorter rod will 60ft better.
Re: New 470 build needs your help!!! [Re: viperblue72] #1258467
06/30/12 01:05 PM
06/30/12 01:05 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Me too, i could only remember the 1.32ch so I assumed the rods were as you posted
Doug
Re: New 470 build needs your help!!! [Re: Sledge_57] #1258468
07/02/12 12:56 AM
07/02/12 12:56 AM
Yea I have been looking at the 1.320piston and 6.7 rod. The pistons are over $700 with no rings, by Diamond Racing.
Re: New 470 build needs your help!!! [Re: DanteGray] #1258469
07/02/12 12:17 PM
07/02/12 12:17 PM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
Call Eric @ Muscle Motors Great guy great products!!!! cant beat prices either!! KB icon pistons are 500 same piston as 451
Re: New 470 build needs your help!!! [Re: 71Pan] #1258470
07/03/12 10:06 AM
07/03/12 10:06 AM
I called Keithblack pistons will have too much compression (Flat top w/ 4cc valve reliefs) about 11.9 static and weigh 559g and Diamond have a 12.5 cc dish about 10.9 static and weigh 537g.
3.915/2+6.7+1.320=9.9775-9.980=0.0025 below deck
Re: New 470 build needs your help!!! [Re: DanteGray] #1258471
07/03/12 10:55 PM
07/03/12 10:55 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
470 ci low deck with SR heads.
