Magnaflux and why we recommend it. #1258412
06/27/12 06:59 PM
06/27/12 06:59 PM
Delray beach, Florida
P
Performance Only Offline OP
P
here's some pictures of a crankshaft a customer brought in to have us modify for his application. we almost always recommend magnetic particle testing on crankshafts.
had we not found this now, i'm sure the owner would've found it in short order the hard way.
machine shop owner and engine builder
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258413
06/27/12 07:00 PM
06/27/12 07:00 PM
P
P
take 2
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258414
06/27/12 07:04 PM
06/27/12 07:04 PM
P
P
and finally
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258415
06/27/12 07:05 PM
06/27/12 07:05 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
NDT is a very cool thing!!!!!
Re: Magnaflux and why we recommend it. [Re: Moparnut426] #1258416
06/27/12 07:10 PM
06/27/12 07:10 PM
Texas
E
ef8Cuda340 Offline
ef8Cuda340  Offline
E
Texas
Can't imagine it being anything else other than a fatigue crack.
Re: Magnaflux and why we recommend it. [Re: ef8Cuda340] #1258417
06/27/12 07:22 PM
06/27/12 07:22 PM
Moparnut426 Offline
Moparnut426  Offline
And unless ya have it radiographed you wont know how deep it is.
I cant imagine too many engine shops have an x ray machine at their disposal.
Re: Magnaflux and why we recommend it. [Re: Moparnut426] #1258418
06/27/12 07:34 PM
06/27/12 07:34 PM
FastOne Offline
FastOne  Offline
ouch!
Re: Magnaflux and why we recommend it. [Re: FastOne] #1258419
06/27/12 08:14 PM
06/27/12 08:14 PM
Arizona
Chris'sBarracuda Offline
Arizona
Very Cool Dan..
I mean the pic.. Not the crack..
As always..
Chris..
Re: Magnaflux and why we recommend it. [Re: Moparnut426] #1258420
06/27/12 09:12 PM
06/27/12 09:12 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
They can also use ultrasonics to find the depth of the indication. I've been working on a 1,000,000 HP/1 billion dollar steam turbine that self destructed for the past 3 weeks
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258421
06/27/12 11:06 PM
06/27/12 11:06 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
How does the crank sound when you tap the counterweight with a hammer? I'm curious because I've seen cracked cranks before, pretty sure they were cast, and when you tapped it with a hammer, there was no ring. It was a bit of a dull sound, not the type you have to grab the counterweight to make it go away.
Re: Magnaflux and why we recommend it. [Re: dodgeboy11] #1258422
06/27/12 11:59 PM
06/27/12 11:59 PM
P
P
just so everybody knows, those 3 pictures are 3 different journals. all 4 rod throws have cracks, i just didn't photograph the last one.
if someone were to base whether or not this crankshaft was any good based on how it rings, they'd think it was perfectly fine. on three of those journals the cracks run more than half way around the journal. basically it's a failure waiting to happen.
i wanted to post these pictures for a couple of reasons so i'm glad you asked about how it sounds, or whether it rings or not. sometimes a cracked crank will have a dull ring, but other times it'll still have a nice clear ring like this one.
another reason i posted this is because i don't think i've ever seen anyone post pictures of Zyglow under UV lighting. i think a lot of people don't really know much about the process or what their machinist is actually doing or looking at to qualify whether or not their crankshaft is fit for service. it's not like this is high tech or anything like that, but it's a great, cost effective method with crystal clear results.
just as a side note, every now and then what appears to be a crack isn't a crack at all, but perhaps a grease line or some other annomoly that appears as such. often times a little bit of very light sanding and those will disappear. actual cracks won't disappear when you do that since the particles will remain in the crack below the surface.
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258423
06/28/12 01:03 AM
06/28/12 01:03 AM
Wow, I sure hope that isn't my crank.
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258424
06/28/12 11:23 PM
06/28/12 11:23 PM
P
P
i wonder if a should have posted this in the Question and Answer forum where their might be more interest? i didn't think about that until i got a call from a member here asking why i even posted it.
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258425
06/28/12 11:28 PM
06/28/12 11:28 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
I, for one, am glad you posted it...here! I would have never seen it in the general section. I don't post here much, but I learn alot from these kind of posts. THANK YOU!
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258426
06/28/12 11:34 PM
06/28/12 11:34 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I saw this but didn't have time to post.
Very interesting and thanks for taking the time
Until now even after all the machine shops I've been in I've never actually seen first hand what the process looks like
I'm afraid to mag mine
when it was index ground one rod throw was off enough to remove the radii on 1/2 the journal
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258427
06/28/12 11:45 PM
06/28/12 11:45 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
WHat kind of crank was it? And what use did it see before? Street or pure race?
Re: Magnaflux and why we recommend it. [Re: Twin Turbo Mower] #1258428
06/29/12 12:03 AM
06/29/12 12:03 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Dan , glad you posted those pictures, shows what may turn into a bad situation if if the engine builder didn't Zyglo the parts before the machine work or the build.
Re: Magnaflux and why we recommend it. [Re: rowin4] #1258429
06/29/12 01:57 AM
06/29/12 01:57 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
WE got our wet magnaflux machine in 1973,It is one of the most importent machines in our shop.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Magnaflux and why we recommend it. [Re: BIGSPEED] #1258430
06/29/12 03:53 AM
06/29/12 03:53 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Dan, I take it that you used the Magnaflux Zyglo process, we used to use that process to inspect turbine blades and turbo shafts, also used the magnaflux spot check system but zyglo will go where most anything else won't.oh by the way,,nice catch.
Re: Magnaflux and why we recommend it. [Re: Performance Only] #1258431
06/29/12 09:07 AM
06/29/12 09:07 AM
Texas
6packattk Offline
6packattk  Offline
Texas
I am an information sponge,as for the miserable people who love passing it around simply ignore them.Thanks for the pictures
