273 rocker arms #1258183
06/27/12 09:46 AM
06/27/12 09:46 AM
West Tennessee
rbstroker Offline OP
West Tennessee
I have a set of stock 1965 273 adjustable rockers installed on my 360 powered Dart. They tend to loosen up over time. There are no jam nuts on the stock setup. I think that the original factory idea was to have an interference fit between the adjuster and the rocker threads. The thread is 3/8-24. I have some thin 3/8-24 hex nuts. Do I need to have the rockers spot faced before using the hex nuts as jam nuts? I am concerned about the nuts actually coming loose and coming off of the adjuster screw. Any other suggestions to maintain the rocker adjustment?
Re: 273 rocker arms [Re: rbstroker] #1258184
06/27/12 11:02 AM
06/27/12 11:02 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Id face the tops for the locknuts just for safety sake. OR maybe you could spike them to get the interference fit back..
I am truckless..
Re: 273 rocker arms [Re: rbstroker] #1258185
06/27/12 12:22 PM
06/27/12 12:22 PM
Blue loctite on the threads
Re: 273 rocker arms [Re: RapidRobert] #1258186
06/27/12 12:49 PM
06/27/12 12:49 PM
dogdays Offline
dogdays  Offline
Very carefully squeeze them in a vise. Or use a Vice-Grips. Go something like 1/4 turn past snug.
R.
Re: 273 rocker arms [Re: rbstroker] #1258187
06/27/12 01:25 PM
06/27/12 01:25 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Hex pal lock nuts! seen them used for that with success
scroll down a bit!
http://www.mrgusa.com/pdfs/83-89palnut.pdf
Re: 273 rocker arms [Re: rbstroker] #1258188
07/23/12 01:31 PM
07/23/12 01:31 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Hey RB, did you have any interference with the springs?
thx Diego
Re: 273 rocker arms [Re: Diego_Ted] #1258189
07/23/12 02:24 PM
07/23/12 02:24 PM
West Tennessee
West Tennessee
thx Diego
No problem whatsoever. Comp springs, retainers, and keepers. No rotators.
Re: 273 rocker arms [Re: rbstroker] #1258190
07/23/12 03:20 PM
07/23/12 03:20 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Thx RB, I was told they are hitting my springs, I know many have used them with no problems? Not sure what is going on with mine?
thx Diego
